3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: locomotive2111 on June 28, 2022, 08:49:10 AM
Hi everyone, I was having an unusual misfire condition and after much research and study I found the answer. The problem was caused by worn distributor shaft bushings which caused the points dwell to vary greatly . Dwell of course is the time the points are closed which relates both to timing which affects idle and coil saturation or voltage at the plugs. Here is a web site that really explains it better. www.howacarworks.com/ignition-system/checking-the-dwell-angle. I know you can avoid this problem with a conversion to electronic ignition but us purists like points. I spoke to a race car builder who explained the need to maintain the distributor to get peak performance. Good luck and keep on Jeepin.
Or just put new bushings in your distributor
