Your Projects => Your CJ-3B Project => Topic started by: Sammydida3B on March 09, 2021, 09:57:48 PM
Title: My 54 3B build
Post by: Sammydida3B on March 09, 2021, 09:57:48 PM
Making progress.
Title: Re: My 54 3B build
Post by: PercyUK on March 10, 2021, 03:46:32 AM
Looking good, keep us updated
Post by: Sammydida3B on April 06, 2021, 09:47:10 PM
I'm not sure you can ever be finished.
Post by: squidtone on April 07, 2021, 12:09:02 PM
I love the "slots"!
Post by: Sammydida3B on April 07, 2021, 05:15:06 PM
I looked for a long time to find an affordable set of four. They are original forged aluminum from the mid 70s Levi's edition. Now I'm looking for one more for my spare.
Post by: Sammydida3B on April 07, 2021, 05:49:41 PM
I installed a 1975 Buick 231 odd fire. With the Sanderson headers and Flowmaster mufflers it runs pretty good
Post by: Sammydida3B on April 15, 2021, 07:03:20 PM
Finished the front bumper and winch.
Post by: Sammydida3B on April 23, 2021, 07:39:37 PM
I don't have to go topless anymore.
Post by: Rus Curtis on April 24, 2021, 12:42:36 PM
Sammy,
Is that the same top out of PR discussed here in Scott's thread?
https://cj3apage.com/Forum/index.php?topic=5078.0
Post by: Sammydida3B on April 25, 2021, 12:03:13 PM
Rus I was starting to think I wouldn't be able to find one.   Here is the web site where I ordered from.   https://somarmotor.com/bikini-top-for-cj3b-spice/
Post by: Rus Curtis on April 25, 2021, 01:30:27 PM
yep, that's the one.  Can you post some more images for side and back?  And up close for material detail?
Post by: SteveKfl on April 25, 2021, 02:13:49 PM
Note Contact info is Florida...
CONTACT US
1319 Green Forest Ct Unit 401, Winter Garden, FL 34787
1-407-614-1141
info@somarmotor.com
Post by: Sammydida3B on April 25, 2021, 02:44:49 PM
Here's a few pictures of the top.
Post by: Rus Curtis on April 25, 2021, 05:38:09 PM
Looks real good!  Color choices too!
Thank you.
Post by: Sammydida3B on April 27, 2021, 06:57:00 PM
Back to the build. I'm attaching a few pictures of the problems I had to overcome. The bellhousing needed a little more room. Also the engine being farther back wouldn't allow the emergency brake cable to go into it original location. I routed it around the transmission mount and up through the floor to the brake handle pictured.
5/1/21
The transmission/transfer case was pretty loud so I checked the gear oil and found lots of metal. I'm in the process of switching them out with a spare I've had in the corner for a while. Just waiting for the seals and a few other parts to put it back together.
Rebuilding both should be a good project for next winter.
Post by: Sammydida3B on May 18, 2021, 09:03:11 PM
My back bumper and spare tire carrier is almost finished. It's coming out pretty good.
Post by: Rus Curtis on May 18, 2021, 10:38:42 PM
That's a stout looking bumper.  Will the pivot have a grease fitting?
Ron
   It had one but I decided that I probably wouldn't be putting very many miles on the bearings (considering the fact that they would turn about a quarter of a revolution once in a while) I deleted it.
   It is a very stout bumper. I used 3" victolic or in English "fire suppression pipe". It's about 1/4" thick. Heavy but not too heavy. Below is a shot of the front bumper.
Post by: SteveKfl on May 19, 2021, 07:26:19 PM
To me, "lack of frequent use" would be more of a reason to make sure it is greased to keep condensation out of the bearing from sitting idle in an air pocket.  An "ounce of prevention", if you will.  Nice work on both ends and in between too.
Post by: Sammydida3B on May 19, 2021, 08:59:12 PM
SteveKfl
    You might have a good point there. I'll check it after some time and if there's an issue I'll clean things up and drill a hole. Thanks for the positive feedback. It's been challenging at times but always rewarding. It not the destination but the journey.
Post by: Sammydida3B on May 23, 2021, 09:38:34 PM
Well the 3B is finished. I guess it's time to do the 2A.
Post by: Sammydida3B on October 30, 2021, 08:27:21 PM
Update: Wow!!!  Five months ago I said that the 3B was finished. Here it's the end of October and after four engine swaps it is running very well. The 231 Odd FIre is really strong. What a super fun little jeep.
Post by: tow hook on April 12, 2022, 01:56:43 PM
CONTACT US
1-407-614-1141
info@somarmotor.com
when i called to day they said he didn't have one that fit the rope channel, i see that they do make them. so i'll check around for one instock. thanks
