3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: aboyandhisdog on November 18, 2011, 06:50:50 PM
Title: Strange noise
Post by: aboyandhisdog on November 18, 2011, 06:50:50 PM
I've had a noise for a while now that I can't for the life of me determine what it is all about.  It sounds like small rocks in a coffee can or like a metal cap on top of a semi tractor exhaust pipe - those "flappers" that keep the rain out.  Anyway, it's that kind of a metal flapping against metal sound.  It ONLY happens when the accelerator pedal is being "feathered" between accelerating and decelerating.  In other words, foot on the gas - no noise, or, foot off the gas - no noise.  In between - rattle, rattle, rattle.   At first I thought I had a loose heat riser valve that was vibrating but have ruled that out.  I've taken it apart and it is very solid as it should be.  I also wired it in both the open and closed position, and no difference - noise still there.  Also, the jeep needs to be driving - no noise if I'm sitting still and just running the engine.  A mechanic friend of mine threw out the idea of the oil slinger making the noise but, if it was the oil slinger wouldn't it do it all the time?  And, can the oil slinger really be loose like that and what would it be hitting if anything?  That is probably a red herring, but I am at a loss.  Almost everything is new or rebuilt and my 3A runs great.  Strong oil pressure, and all systems normal!  Any ideas???
Title: Re: Strange noise
Post by: Bob W on November 18, 2011, 08:40:00 PM
Out of phase driveshafts can make all kinds of weird noises like that.
Post by: calvinhunt on November 19, 2011, 01:21:45 AM
Tom,
 ï¿½You have described exactly what I have been searching for now for more than two years. �It didn't do it the first summer after the restoration was completed. �After the first summer I removed an engine that was about to self-destruct and installed a second overhauled engine. �At that time I replaced all my aftermarket gears in my transmission and reinstalled all NOS gears. That's when the noise started.
 ï¿½I first thought it sounded like a loose spring clamp rattling. �I believed it well enough that I let it go for quite some time, then I decided I would rule that out and wrapped duck tape around any that were loose. �A test drive told me I didn't find it. �BobW was here and I asked him what he that it was. �He felt it was inside the bell-housing. �A few weeks later Carlsjeep was here and he, like you, thought it was the heat riser. �We wired it tight. �No change. �There is a recently-restored CJ-5 here in town that makes the same noise. �
 ï¿½If you ever figure it out please let me know and Ill do the same for you. �
 ï¿½BobW, now that I've brought this up again here, even after your above suggestion to Tom, don't you feel it's the same noise I had you listen too, only happens between compression and pulling--just floating. I pulled the tranny just this afternoon to replace the synchro blocker rings as I said I was going to do. �I don't see anything in the clutch disk that would cause the noise. Any things else to look at in there while it's open?
 ï¿½Carlsjeep, any new ideas.
 ï¿½Come on guys, we need help solving this mystery. �Thanks.
Post by: Gunslinger on November 19, 2011, 07:51:55 AM
Without being able to hear it its kind of difficult to guess, but It sounds like what ever it is, its quiet under load, and vibrates when the load drops off.  I've seen that in a couple of different circumstances; the bell housing cover could do it if not allof the bolts were tight; remote.   I've seen a cracked belt pully do that as well, I've also seen a water pump make some weird sounds as well, and sometimes it sounds like its quite, but other noises just overwhelm it and you only hear it when going slow..
Curious issue
Post by: aboyandhisdog on November 19, 2011, 12:54:07 PM
Calvin, now you have me thinking about the clutch/driveline.  This noise started after I put in one of KW's used engines, so I made the assumption that it must be in the engine or engine-related somehow.  However, now that I think about it , we did the clutch and throwout bearing (and water pump) at the same time.  After everything was buttoned up, I had the noise.  I'm looking at my manual and I see things that could rattle like this:  Throwout lever spring and return spring,  worn flywheel pilot bushing,  "fingers" improperly adjusted???  (Not even sure what this means)  I'm no mechanic and some of this is over my head, but I have to believe we are not the first to be down this road.  SOMEBODY just has to know what we are hearing.  The next time I'm out in the jeep, I plan to see if it goes away when I press in slightly on the clutch pedal, maybe this will help with diagnosis.  I really appreciate your help!
Post by: Carls_jeep on November 19, 2011, 10:40:14 PM
Ok, have ya'll checked to see if the yokes are in line on each drive line? I hadn't thought about that until it was mentioned here. If you remove the drive shafts one of the spline ends could come off and when you put it back it may be one tooth off or more.
EDIT: what about the old service bulletins, did any of them mention a similar vibration?
Post by: calvinhunt on November 21, 2011, 01:16:29 AM
Tom,
  As I said a couple of days ago, I now have the transmission out.  I'm looking for anything with my clutch plate or pressure plate (which are not removed) that may be the culprit.  I've even called a couple of people who I believe to be experts but still no great leads.  I think maybe we should bring it up on the CJ-2A page but I haven't registered there.  Not many 3As compared to 2As.  Surely someone has solved this problem in the past.
  I know our problems are the same, you have identified it exactly as I have experienced it.  If you figure it out I'd be anxious to know what you find and if I figure it out I'll be anxious to share it with you.  I'm glad you are working on it too.
  I'm reinstalling my tranny tomorrow afternoon.  I'll check here just before I do to see if you or anyone else has an idea of something inside the bellhousing that I should check prior to the install.
Post by: F Bill on November 21, 2011, 09:03:51 AM
I know it is too late for you as ya have the tranny out but when we had this sort of problem often we would set the vehicle up on a lift and run it while poking around underneath to pinpoint the problem. This can be dangerous if you don't have the vehicle supported well, so be really careful if you try it. � The best way to do it would be a drive on platform lift , using jacks to lift the rear axle (or both if it only shows in 4WD) If you have a friendly shop nearby that doesn't mind ole jeeps, it may be worth paying them to do this... �A stethescope and a pry bar help to locate mystery noises. (Harbor Fright has the Stethescope.)
Some possible rattle points....exhaust system, pedals,clutch and brake linkages, shifters, sheet metal panels, loose parts in the toolbox or on the floor, driveshafts (out of phase, bad u joints, loose yokes) parking brake assembly and linkages, throttle linkage, �etc, etc.
On your clutch look for loose springs in the driven disc, or a loose center assembly. The pressure plate could also have loose parts.. Striking the flywheel lightyly with a deadblow hammer may reveal a rattle which you can then track down, if it is in the clutch.
Post by: Carls_jeep on November 21, 2011, 09:07:47 AM
Tom and Calvin, I just remembered something to look at. Some clutch plates have springs in the center section of them and are to dampen the engagement of the clutch. If the springs break or become loose you could get a rattle there. When I listened to Calvins noise it was more like a rattle than a vibration but when we tied the heat riser open it didn't change.
Look at your clutch plate to check for loose and/or broken springs.
Post by: calvinhunt on November 21, 2011, 03:43:51 PM
Thanks gents,
 ï¿½I do appreciate your input as to what might be causing the problem. �Even though the noise only occurs when the drive train is not loaded (doesn't happen in either acceleration or deceleration), I am willing to try any and all suggestions. �The noise didn't bother me as much as the challenge to find it now does. �I'm glad that aboyandhisdog is on board with the challenge. �Actually, I'm glad that so many of you have joined in. �
 ï¿½I'm going to go install the tranny but will give the clutch disk and pressure plate another close look first.
 ï¿½Thanks again.
 ï¿½Calvin
Post by: calvinhunt on November 22, 2011, 12:04:19 AM
I did take that closer look prior to installing the tranny.  I may have found the elusive noise.  Can't be sure at this time but I feel its a good enough lead to cause me to delay the installation of the tranny.  I see that the center of the clutch disk is lose, as it should be to an extent, but not as lose as this one.  It's so lose that it rattles.  I've ordered a new clutch disk.  When it arrives I'll install it, then the transmission.  Then I'll go for a test drive.  I hope to be able to report that the "strange noise" is no longer.  I'll let you know.
Post by: aboyandhisdog on November 22, 2011, 10:41:15 AM
Thanks, Calvin.  Makes sense - we both had the noise after putting in a new clutch disk.  I will anxiously await your results!  Do you know what the brand of your previous clutch was and the brand of the new one?  Maybe there are some defective clutch plates out there.
Post by: calvinhunt on November 23, 2011, 02:15:44 AM
Actually, when I did my restoration the clutch disk was one thing I chose to reuse.  It seemed to be in good shape.  That was a mistake.  It seems that the items I decided to let go and reuse during my restoration are the only things that are needing attention as time goes by.  Still anxious to see if this is the cure to my "strange noise".  We'll see.  I have ordered the new disk from Walcks.  I hope it doesn't have the problem right from the start.  Again, we'll see.
Post by: Jesse on December 06, 2011, 12:38:52 PM
I wish I could record it for you to compare with your noise, but my jeep makes a very strange noise as well. Turns out it is the tool box lid. This sounds way too easy to be your problem, but mine does rattle at various times while driving or sitting still. It sounds bad, bad enough that I though something was wrong until the lid was noticed.
-Jesse
Post by: aboyandhisdog on December 06, 2011, 12:48:52 PM
Appreciate your input.  But not a problem with mine, nor the tools inside.  This said, the noise IS of the type that it just seems like the fix should be SOOO obvious, and yet...it is very elusive and no doubt internal as suggested previously.  I am anxiously awaiting Calvin's findings upon replacing the clutch disk, but it sounds like it may be a while before he can drive his jeep again to see if that was the problem.
Post by: dtgolder on December 10, 2011, 02:15:21 PM
Thoughts from other cars:
Pilot bearing for first motion shaft (sorry if some of my terminology may be Brit car based) but did have a pilot bearing issue that did that, along with possibly the release bearing/fork rattling.
Pressure plate and clutch disk also sound like possible culprits (Jag granny's had that kind of noise and it is often poorly staked rivets)
Stuff like that is often really tough to pin down
Post by: calvinhunt on December 10, 2011, 10:24:02 PM
�I am anxiously awaiting Calvin's findings upon replacing the clutch disk, but it sounds like it may be a while before he can drive his jeep again to see if that was the problem.
I have completed the installation of a new clutch disk and the re-installation of the transmission. �I test drove my Jeep today. �The strange noise is still there. �It is absolutely unchanged. �Having found the center hub of my old clutch disk loose I was so sure that I had found the problem that I waited for a new clutch disk to arrive. �However, the elusive strange noise still exists.
Okay, Tom, now the ball is in your court. �It's your turn to chase some wild idea. �Of course I didn't take out my tranny just to look at the clutch and associated components. �After the test drive I prepared my Jeep for winter and put it in its little garage to hibernate for winter. �I'll rejoin you in your search for the strange noise next spring.
Post by: aboyandhisdog on December 10, 2011, 11:21:41 PM
Thanks, Calvin - that's disappointing but I'm sure we can get this figured out in time.  I sure appreciate you're giving it the good ole college try.  I have replaced everything that is "brake-related" in the last couple of weeks and will drive my jeep in a few days, but we can probably rule out a brake related noise anyway.  It never seemed to be coming from the brakes.  I feel like this has now become my "Everest" and I just can't let it go.  Fortunately, I don't get a real feeling that the cause is necessarily harmful - would you concur?  More just annoying.  Keep in touch if you have any ideas or need for me to try anything.
Post by: calvinhunt on December 12, 2011, 12:36:08 AM
I don't get a real feeling that the cause is necessarily harmful - would you concur? �More just annoying. �Keep in touch if you have any ideas or need for me to try anything.
No, I don't feel that it is something that is going to let us down if we don't find it.  Like you said, it seems like it should be so easy to locate.  I can't let it go, but it will be an issue for me to take up again when the weather warms up.  You get 40 units of respect if you find it before then.
Post by: BrianW on December 20, 2011, 09:17:29 PM
Hello All,
I had a very similar noise in my 2A.  It went away after I tightened the hardware (two bolts & nuts) that attach the gas pedal to the floor.  Might be worth a try . . .
Post by: calvinhunt on December 21, 2011, 12:33:59 AM
Hello BrianW,
  Welcome to the CJ-3A Page Forum. Thanks for your suggestion.  When we find it I'm sure it's going to be something as simple as that.  However, even though my Jeep is in cold storage for the winter (hiding in it's own little garage and under a car cover) I went out and checked the two bolts you identified.  They are completely tight.  Remember, our noises do not occur when in acceleration or deceleration.  Thanks again for trying.
Post by: aboyandhisdog on June 30, 2019, 01:31:04 PM
Well, Calvin, after all this time I finally have a solution.  It didn't go away after I put in a new engine.  It didn't go away after I R&R'd my clutch.  But I just put in a new throw out bearing and carrier, and now NO NOISE!  I can't say for sure if it was the bearing or the carrier or both together but I just came in from a long drive and could not reproduce the noise at all.  So, next time you're "in there" - well, there ya go!  This assumes, of course, that we were both chasing the same noise.
Post by: GaryM on July 01, 2019, 01:22:38 AM
I had a similar noise when I first put everything together on my 3B and was driving it around without the body tub. My noise also happened in no load situations--the minute I touched the clutch pedal it would stop. It turned out that the pilot bushing was turning in the back of the engine. Pushing the clutch pedal put a load on it and stopped it turning. I installed a new bushing, which had to be hammered in, and the noise was gone. I hope this helps.
Post by: aboyandhisdog on July 01, 2019, 09:37:40 AM
That is interesting, Gary.  I forgot to add that I also replaced the flywheel bushing at the same time, so it is possible that THAT was the cause.  So I guess I can't know for sure, but we have definitely narrowed things down.  Thanks for the input.
Post by: calvinhunt on July 02, 2019, 02:54:01 PM
Thanks for remembering me.� It has been a long time.� I have since retired and moved from the Southeast corner of the state of Utah (Blanding) to the Southwest corner of the state (Santa Clara - near St. George). My wife and I love it here but we do not have the variety of trails my previous location provided.� I have not found anyone to ride with so I don't venture out any further than I care to walk home from.� I usually only drive when grandkids come and want to ride in the Jeep or when carlsjeep comes from Kentucky.�
I certainly am still annoyed by the "Strange noise".� Since my last post I have tried so very many major things.� I am now anxious to try pressure on the clutch after the post from aboyandhisdog to see if I can get any change in the noise.
Thanks to all who have given suggetions.�
Post by: Gunslinger on July 17, 2019, 11:38:44 AM
Calvin,
Welcome back, we have missed hearing your stories of trekking the wilds of Utah.  My spouse and I were in Moab hiking with some friends this past spring, certainly understand why this area draws so many visitors, beautiful country.
