3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: PaulS on July 02, 2016, 09:25:15 PM
Okay, I said I'd have some simple questions... Here's a couple more. (And I checked my pictures before posting this time, but no luck there.)
I bought the engine/tranny mount kit at Walcks. The engine mounts are obvious.
I know the big donut goes in the circle on the cross member. But how is it installed? (I remember getting the old one out, but it was 65 year old rubber and I didn't care if I destroyed it!) Is there a trick to getting it in? And which way is up?
The rectangular one with the two studs. It's pretty clear from the holes in the cross member where it goes. Does the side with the two dents point forward?
Where do the little donut and the special bolt go?
-Paul
I think the only help I need now is getting the large donut into the ring on the cross member. Anyone done this? If so, how?
-Paul
Okay, never mind. Hawk solved the problem for me on the CJ2A forum.
Turns out there was a steel ring that was part of the old mount that was still there... ::)
