3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: PaulS on July 01, 2016, 09:00:07 AM
Does the tranny cross member bolt on below the frame, or does it fit inside the frame rails?
-Paul
Below the frame...
Will yours fit inside the frame?
Not a great picture but it's all I can find for now...
Thanks! I didn't measure to see if it would fit--I just tried to insert it, and I was wondering if it needed "persuasion". But putting it underneath is easier, if that's where it's supposed to be!
It's been so long since I disassembled it, I'm sure I'll have lots more simple questions like this over the next few weeks, as it goes back together.
-Paul
Should have looked in my own archives before posting!
(http://www3.telus.net/plsmjs/jeepblog/tranny-x-member.jpg)
-Paul
Well, there you go....and your picture is better than mine..
I took a lot of pictures...sometimes I don't know what they were for...but they are fun to look at...
And I put all the nuts and bolts in baggies and then scribbled some gibberish on them assuming I would be able to decipher them months later....
I did the same thing with the bolts and some parts thinking 6 months down the road I could remember what I was doing when I forget what I did 10 minutes ago sometimes. I just took lots of pictures and emailed them to myself for reference. That helped more than anything. Things I missed I would google and find pictures to go by. Good luck.
I have lots of pictures, too, but I didn't always take pictures where I should have. I'm expecting to have trouble reassembling the clutch and the pedals and linkages around there...
When I pulled apart the engine, transmission, and transfer case, I was very diligent about using baggies. And those (mostly) went back together without problems. But I didn't use baggies when I pulled things off the frame.
-Pau
