3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: specialty on April 22, 2016, 08:38:26 AM
On the steering knuckle what holds the 140 wt. oil from running back into the axle tube? The brass thrust washer? Seems like a rubber seal would be in there.
I think there is an inner axle seal in the diff housing.
I have sense discovered that. I had bought seals that I thought went to seal off the axle from the knuckle side but as it turns at after looking at diagrams it's in the differential side. Thanks
