3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: JimVillers on March 24, 2016, 02:15:27 PM
Title: Fuel Line Fitting
Post by: JimVillers on March 24, 2016, 02:15:27 PM
Another item that I am trying to figure out is the routing of the fuel line.  I have the pre-formed line that "looks perfect".  Of course it cannot be installed without cutting the line or removing the steering box or something else.
I located this image on the routing of the line.  It does not look possible to use the "correct path" because of the clutch pedal.  Are either of theses paths correct?
Title: Re: Fuel Line Fitting
Post by: scoutpilot on March 24, 2016, 02:53:20 PM
[size=12]While the dashed line is the correct factory set up, the other route is easier and the plan of choice for most. Back then, no one expected that fuel line would need replacement.[/size][/b]
Post by: Mike S on April 09, 2016, 04:01:40 PM
Can anyone tell me where the clamps for the fuel line are located and attach?
Post by: Bob W on April 09, 2016, 06:54:56 PM
http://www.cj3a.info/tech/line.html
Post by: Mike S on April 10, 2016, 03:52:18 PM
Thank you. Very helpful.
