3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: BMIC on June 01, 2015, 10:37:26 AM
Title: Setting the Point Gap
Post by: BMIC on June 01, 2015, 10:37:26 AM
I am 2 months into the 6 month curse Ryan put on me when he said "When you thing your project is done, you have 6 months of chasing gremlins left". While my carburator is off being rebuilt I decided to do a tune up...points, plugs, cap, coil, and wires. All is going smoothly until I try to set the point gap to .020. With the fiber guide sitting on the high lobe I cannot get the gap to .020. With the eccentric screw turned all the way closed the gap is still about .030.
What am I missing here? All new parts from KA....
Title: Re: Setting the Point Gap
Post by: athawk11 on June 01, 2015, 11:19:12 AM
BMIC,
Based on what you wrote, I would say you may have the wrong point set, or it's not installed in the correct position.
Can you post a photo?
Post by: scoutpilot on June 01, 2015, 11:47:18 AM
X2
Post by: Ryan_M on June 01, 2015, 12:02:37 PM
If it's the wrong point set I went though that too. Once I ID'd the right set of points I saved the box so I could just bring it back to CarQuest every time to ensure I got the right ones. Trying to figure it out all over again each time was too much of a hassle. I think NAPA has them too.
2 months down, 4 to go...if you're lucky  ;D
Post by: BMIC on June 01, 2015, 12:59:39 PM
Thanks guys... I do have the packing box as well as invoice. It is such a simple procedure, I must have installed/uninstalled 10 times last night thinking I missed something. Another hint may be that the condenser wire was about 2" too long.
There is a NAPA on my way home tonight, I'll try them...
Bruce
Post by: stony on June 02, 2015, 12:35:22 AM
Setting the points dwell rather than setting the gap should give you better results, and assure that your coil is getting a full charge.  A dwell meter is only about $30 and well worth it.  Once the dwell is correct, then set your timing and you should be good to go.
Post by: Ryan_M on June 02, 2015, 07:01:28 AM
I absolutely agree on using a dwell meter, although, within the next couple weeks my guess is you will be able to get the gap set to surprising accuracy by eye alone (or, that's an embarrassing indication of just how long I had to monkey around the first time through  :D)
First off, you need to find the right set of points.
Post by: scoutpilot on June 02, 2015, 12:03:34 PM
[size=12]CS-725A[/size][/b]
Post by: BMIC on June 02, 2015, 01:51:57 PM
Stopped by NAPA and picked up a new set of points and condenser, planning on installing them tonight. As usual I like to read the 3A page over lunch and read scoutpilots brief but always accurate post "CS725A". Walked out to my car to verify that's what I had and you guessed it CS709. Quick trip back to NAPA and picked out the oldest counter guy available and got him to dig out the books not the computer and find the right points. The NAPA computer does specify a CS709 for a 1050 3a so you have to get them to go old school to the books.... or tell them you got the number from higher authority Scoutpilot.
