3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: athawk11 on May 03, 2014, 09:22:34 AM
(http://i1195.photobucket.com/albums/aa397/athawk11/athawk11%20Willys%20White/70ac6faa0b4241a6820ed53c0b5162be_zps32ef04ae.jpg)
This pump leaks fuel from the holes indicated with the blue arrow.� Some reading leads me to believe this has a ruptured diaphragm.
Looking for a consensus from the group.� Time to rebuild?� Or is this thing a gonner?
By the way, the thing pumps fuel like a grape ape, so I'm a little confused.
I agree...ruptured diaphragm.....I think it will also allow fuel into the oil pan....
or,
I understand that some of the AC pumps had the plunger fastened to the diaphragm with a nut and washer, others were peened.� Maybe the nut came loose and is allowing a little fuel to leak by? The top will come off pretty easily( 6 screws) for inspection..you might get lucky...
Kits available here...
http://www.classicpreservation.com/fuelpumpkits.html
Thanks for the link Randy.
I did get a hold of Hal. Decent price. $53.00 for a rebuild kit. Made in the USA with parts that hold up the the alcohol rich fuels.
I am going to get one and rebuild this pump, but it will end up on my OD Willys. I picked up an Airtex reproduction pump for Whitey. Looks pretty good, and seems to work well.
Good choice...once installed you probably won't be able to tell the Airtex from the AC...
When I did my pump, I found that the diaphragm removal(from the push rod) and re-install was probably THE most frustrating part of the entire restoration,after the windshield install of course...
Hal offers a service where you send in your old diaphragm and push-rod and he will install the new ones, out of your new rebuild kit.....IF your pump has the peened type diaphragm I would personally let Hal do it....if they are the nut-and-washer type then no problem....even a caveman could do it ;D
I got an Airtex over a year ago and can't say I have any problems with it. I can't compare it to anything, but my M38 still moves forward. I don't know about the performance of the vacuum function, I don't have a top and I don't feel like getting wet. :)
Oh bubba said, JB a weld will seal those holes up ;D
Hey Tim,
Have you done anything on the fuel pump yet? I read your post in the High Altitude thread and am starting to think that a spare pump would be a good idea....but I suppose a parts store single action replacement would be a good enough backup....
Hi Randy,
I installed an Airtex on the Whitey project.� I have the rebuild kit from the Classic Preservations folks.� I plan to rebuild the original, then install it on my OD Willys.� �Just not a huge priority right now.� By the way, thanks again for that link.
The Airtex is a reasonably priced option for a decent backup.� It has the same vacuum and fuel hook ups as the original, so it would've pretty easy to install while in the field.� A single action pump would also work in a crunch, but you would also want to have provisions to close off your existing vacuum lines.�
I think it was just a bad run of luck on that FCT trip last year.� I believe it was Jpet that had two different pumps installed while on the same trail. Both were brand new after market single action pumps.� Crazy.
Thanks Tim,
I probably should just get the original rebuilt...or do it myself....The originals are so much easier as they have a valve retainer that is screwed on, rather than the Airtex where the casing is distorted with a punch to hold the valves in....I still would have Hal do the diaphragms...
Something else to put on the list....
