3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: Tucker on March 04, 2014, 12:05:32 PM
Hi all,
I'm trying to figure out how much, if any, lift I got when I bought my basket case.� It's a 3A frame, tub, and title.
The rear leaf springs have 13 leaves--military?
The front have 9--stock?
What is the stock measurement from the top of the axle tube to the bottom of the frame?� That, I assume, will give me some sense of whether I have a lift or not.
Hi Tucker,
I don't believe the 13 leaf springs on the rear are stock.� The leaf count on the back is usually 9.
The fronts were 8 leafs and 10 leafs for the heavy duty option.
I can do some measuring tonight when I'm back home, but there may be some differences from what would have been the standard lift.�
13 leafs would make for a really stiff ride.� I do have 9 leafs on my rear, and that seems pretty stiff. :o
From top of axle to underside of frame...5".
Again, 9 leafs.
Thanks for the info!
Mine is at about 7-8"' so I've probably got a two-inch lift since not all the weight of the vehicle is on the chassis right now.
I had a feeling about the 13 leaf pack. Might as well be square tubing for all the give it seems to have.
I think I'll leave them on for now but look around for a rear leaf set closer to 8-10 leaves. It's going to be an off-roader, so I'll need some give.
