3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: SteveW on November 13, 2013, 08:21:41 PM
Title: Horn repair
Post by: SteveW on November 13, 2013, 08:21:41 PM
Done some searching but have not found anything on checking or fixing horns. I am fortunate to have a NOS horn hooked up but have 2 horns still around. Might want to play with them as they don't work so nothing to lose by tinkering.I am talking about the flat faced horns not the ones with the funnel on them.
Title: Re: Horn repair
Post by: 1955CJ-5 on November 13, 2013, 08:33:31 PM
I took mine apart and cleaned it. Mine is the type with about a 2" horn on it, not the really flat ones..
I have more pictures...
Post by: Matto on November 14, 2013, 07:52:28 PM
Here's a link to a horn repair article on the Vernco site.
Lots of good stuff on his site.
http://www.vernco.com/Sparks/id516.htm
Post by: SteveW on November 14, 2013, 09:02:08 PM
Clicked on link and jumped up as an attack page. I guess he is still having problems.
Post by: bretto on November 15, 2013, 07:49:20 AM
The link works ok for me.
Post by: Ryan_M on November 15, 2013, 08:17:29 AM
The Vernco page is blocked by Chrome and Firefox browsers but Internet Explorer will allow it to load. At least that's what's happening on my computer anyways.
Post by: scoutpilot on November 15, 2013, 11:34:41 AM
Reload on Firefox then when you get the blank screen, look in the upper right hand corner for a dialogue box with "ALLOW" in it. Click it. I use USPS.com on Firefox and it does the same thing.
Post by: SteveW on November 15, 2013, 04:28:33 PM
I'm a little skittish after getting creamed a while back. I have Mozilla and it asked to allow it but I passed on it. Will probably give it a look now.
Post by: 1955CJ-5 on November 15, 2013, 05:00:33 PM
Is your horn the type that is bolted together or is it riveted?
If you have continuity through the coil then it's probably just the points that need cleaning or adjusting...
Just pay attention as you take it apart as it needs to go back together  the same way..
Post by: SteveW on November 16, 2013, 08:32:27 AM
I dug them out and I had already looked at one. it is a flat faced Sparton in very poor shape and I had already drilled out most of the rivets. The other is flat faced with a 48 on it and 12v on it. No name that I can see and it appears the outside is crimped on with the face over the rear of case. i will take pics and post them. I remember that I had checked for a reading on the terminals and had hooked it straight up to battery with no results. It's a nice horn and worth checking out.I did look at Vernco site and lived to tell the tale.
Post by: SteveW on November 17, 2013, 04:45:11 PM
Here is the 2nd horn that is unmarked. The screw in the back will not move even with kroil on it and looks like it may have had the body knocked into the threads to keep it from moving.
(http://www.surfacezero.com/g503/data/500/medium/horn_engine_studs_001.jpg)
(http://www.surfacezero.com/g503/data/500/medium/horn_engine_studs_002.jpg)
front center post is definately not meant to be messed with
(http://www.surfacezero.com/g503/data/500/medium/horn_engine_studs_003.jpg)
only markings on it
