3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: Steve on October 11, 2013, 12:14:29 AM
Tonight I started the process of disassembly. Right off the bat I was stumped by how to remove the headlight trim rings from the grill. So, could someone please clue me in on how to get the trim rings off? Thanks.
Steve
Remove the one screw at the bottom then pull the ring out at the bottom and lift it up to release the top.
Mine were really stuck after years of paint, grime etc etc. Massage them gently this way and that and eventually they should pop loose just as Bob said.
I think they are chromed brass so be gentle...
Thanks guys. I appreciate you willingness to help out with little questions like this one. In the past, I would blindly forge ahead and end up trashing something. I am going try and be patient and ask when the potential for destruction is high.
Steve
We are here...
We have been there...
We have destroyed things unnecessarily...
I think about 20 percent of my resto was my own fault....
