3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: PaulS on August 17, 2013, 09:59:32 PM
Title: Reusing bearings
Post by: PaulS on August 17, 2013, 09:59:32 PM
So I'm going through all the bearings in my 25 front and 41 rear axles, deciding which to keep and which to replace.  I wondering what criteria you use to decide this.  Are there any general guidelines?
On my first pass, I'm rejecting a lot of bearings (cups and cones) from the 25, but keeping most from the 41. (I wonder if the 41 has had this done before...)  If I can keep a few more, it would help my wallet.  But if they do need to be replaced, I certainly don't mind the cost.
-Paul
Title: Re: Reusing bearings
Post by: Carls_jeep on August 18, 2013, 01:26:24 AM
The way I judge replacement is if the rollers are pitted and the cone has brinelling on it. Brinellins is pitted lines that run the same direction the rollers lay on the cone. If there are only marks like the bearing in your other post use the bearing again. actual pits that you can feel in the cone or under the rollers on the inner race. Yes, you have to look under the rollers and it's not easy. Sometimes the rollers look ok but the race is pitted.
Post by: PaulS on August 19, 2013, 11:16:55 PM
Okay, So I have selected for replacement the following:
From the 41 Rear:
1 shaft cone
1 shaft cup
1 carrier cone
2 carrier cups
From the 25 front:
2 carrier cones
2 carrier cups
2 pinion cones
2 pinion cups
4 king pin cones
2 king pin cups (the upper one from each side)
The pictures below show parts of all of these:
41 Carrier Cone
(http://www3.telus.net/plsmjs/jeepblog/41_CarrierCone1.jpg)
41 Carrier Cup(s)
(http://www3.telus.net/plsmjs/jeepblog/41_CarrierCup1.jpg)
(http://www3.telus.net/plsmjs/jeepblog/41_CarrierCup2.jpg)
41 Shaft Cone
(http://www3.telus.net/plsmjs/jeepblog/41_ShaftCone1.jpg)
41 Shaft Cup
(http://www3.telus.net/plsmjs/jeepblog/41_ShaftCup.jpg)
25 King Pin Cone(s)
(http://www3.telus.net/plsmjs/jeepblog/25_KingCone1.jpg)
(http://www3.telus.net/plsmjs/jeepblog/25_KingCone2.jpg)
(http://www3.telus.net/plsmjs/jeepblog/25_KingCone3.jpg)
25 King Pin Cup(s)
(http://www3.telus.net/plsmjs/jeepblog/25_KingCup1.jpg)
(http://www3.telus.net/plsmjs/jeepblog/25_KingCup2.jpg)
25 Pinion Cup
(http://www3.telus.net/plsmjs/jeepblog/25_PinionCup2.jpg)
25 Pinion Cone(s)
(http://www3.telus.net/plsmjs/jeepblog/25_PinionCone3.jpg)
(http://www3.telus.net/plsmjs/jeepblog/25_PinionCone2.jpg)
25 Carrier Cone
(http://www3.telus.net/plsmjs/jeepblog/25_CarrierCone1.jpg)
25 Carrier Cup(s)
(http://www3.telus.net/plsmjs/jeepblog/25_CarrierCup1.jpg)
(http://www3.telus.net/plsmjs/jeepblog/25_CarrierCup2.jpg)
The ones I haven't chosen to replace all look good, and feel smooth.� I haven't been able to look at the inner races, though.
Any comments on any of these?
-Paul
Post by: Bob W on August 20, 2013, 09:18:27 AM
Your selection process seems good to me but I'd recommend replacing both the cup and cone on any bearing that looks questionable.
Post by: Carls_jeep on August 20, 2013, 09:33:51 AM
Good point Bob, I always do that and just forgot to mention that fact.
Post by: PaulS on August 20, 2013, 09:51:18 AM
I was wondering if I should do that.  Especially if the cup is the one that's bad (since it's harder to properly inspect the cone).
But if the cup looks and feels good, do you think it needs to be replaced when the cone is bad?
Post by: Bob W on August 20, 2013, 09:56:45 AM
It would probably be okay to reuse the cup.... but generally cups and cones are replaced as pairs. New bearings may not be happy riding on surfaces with wear patterns set up by other bearings.
Post by: PaulS on August 20, 2013, 11:54:19 AM
Okay then.  Since I'll probably be ordering a full brake overhaul kit, plus springs, shocks, and shackles, in addition to all the seals and gaskets in the axles/knuckles, and the bearings listed, a few more bearings will be a small increase overall...
A frame-up rebuild is not a cheap project!  (And I'm still cringing about the thought of the cost of a new body.  But that's likely over a year in the future at my current rate of progress.)  My wife asked me the other day why I didn't just buy a new Jeep.
-Paul
Post by: 1955CJ-5 on August 20, 2013, 12:22:19 PM
Welcome to the club!
I could have bought a fully restored jeep for what I have in the '51.....and it's not done yet....
But what fun is that?
Post by: BMIC on August 20, 2013, 12:50:26 PM
Please don't bring up the money.....
Post by: Matto on August 20, 2013, 08:33:49 PM
I was always taught to keep cups and cones as sets and replace cups and cones as sets. Of course Fafnir Bearing Company was located in the town I grew up in. Their doors have been closed 20 years now.� :(
� Very nice detailed close up pictures by the way.
My $.02
