3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: PaulS on June 15, 2013, 05:51:04 PM
I'm trying to pull hubs.� The first one I tried was from the spare set of axles--which have been sitting outside for years, and probably therefore have a fair amount of rust in them. (These ones have 11" brakes, which I am planning to use on my other axles.)
I bought this big puller (supposed to be rated for 7 tons), and have it on the hub, as shown:
(http://www3.telus.net/plsmjs/jeepblog/_MG_0689_.jpg)
The big (36") blue breaker bar is there to stop the whole thing from spinning. The ratchet that's actually attached to the puller is 18" long and that's a 3/4" socket (for a scale reference).
I'm at the point where I'm standing on the ratchet to get it to advance. And it still is turning that way, but I'm getting concerned that I'm going to break something. Am I doing this right, and should I be concerned about breakage? Is there anything I can do to loosen up the hub?
BTW, I've left the big nut holding the hub on in place, but loosened off by 1/8" or so, in order to prevent the hub from flying off when it breaks free. I have double checked that it's not in contact with the hub.
-Paul
Typically at this point I would remove the� socket and ratchet and give the center threaded shaft of the puller a good whack with a heavy hammer..hit it straight on, driving it against the axle, this ought to loosen things, but if it doesn't...then put the socket/ratchet back on and see if you can turn it a little more....then whack it again....
That is a serious breaker bar! How do you suppose they got that name?
I bought that breaker bar for doing the lug nuts on my tractor...
Anyway, I'm starting to see visible deformation of the hub plate as I tighten the puller, and that can't be good!
I'm not missing something, am I? There's nothing besides that big nut holding it in place, right?
I used a dental pick to clean out all the mud and gunk from the keyway, but there's no way to remove the key in advance, is there?
-Paul
Did you try the hammer? That normally will shock it loose...
A little heat on the hub might help.
Try penetrating oil and let it sit...
Yeah, tried the hammer. I'll let it sit with some oil...
I'm not missing something, am I?�
-Paul
You might not want to hear this but I would shy away from that sort of puller on your hub. At the edge of the hub it has more leverage to bend the hub instead of pulling it.
The puller I would be using bolts to the hub using the wheel studs and lug nuts. Preferably it would have 5 legs instead of three, especially on a hub that is being stubborn. It also would have a large center threaded bolt with very fine threads, a place for the two headed whacker handle , and be well overbuilt throughout. This sort of puller is a lot better at concentrating the force where you want it without bending things.
If I can find a link to one on ebay I will post it.
OTC 7394 is one model...
Here it is being used in a Walck's Video..
http://www.youtube.com/watch?v=PQQvFK4B6pY
Thanks Bill. Those things aren't cheap, are they!
I thought I'd try something different. That 3-jaw puller is big enough to go over the 11" drums, so I put the drum back on, threaded on the lug nuts, and started pulling that way. At least it spreads the load onto all five bolts--even though the metal on the drum there isn't as thick as the hub.
Something was moving when I started applying force, but it didn't seem to be the hub... After the kids get to bed, I'm going back out to try again and see if I can figure out what's happening.
-Paul
I've got one of these three-legged ones. It seems to work fine...at least I've been successful so far pulling hubs..
http://www.kaiserwillys.com/product/1657/willys-jeep-brakes-hub-puller-parts-accessories
Be careful pulling on the outside of the drum. They are cast and the lip is thin. I doubt that you will be able to exert the same force as you did before without breaking something..
One fellow set up the puller with as much force as he could and just let it set that way overnight...he was able to get it apart the next day...
^&$(&(&%*(%$%$# (I'm sure that the forum software won't let me say what I really want to...)
Okay, that was a bad idea. I just wrecked an 11" drum. I seriously doubt it's repairable, but we'll see.
That puller from K-W is a whole lot cheaper than the list price of the OTC puller. At least the price at Acklands-Grainger--maybe I'll see if NAPA or PartsSource has one, and at what price.
But now I probably need to replace an 11" drum, if I want to do that upgrade. I see that K-W lists three different 11" drums (Walcks only has one). How do I tell which ones I've got?
-Paul
Thanks Bill.� Those things aren't cheap, are they!
I thought I'd try something different.� That 3-jaw puller is big enough to go over the 11" drums, so I put the drum back on, threaded on the lug nuts, and started pulling that way.� At least it spreads the load onto all five bolts--even though the metal on the drum there isn't as thick as the hub.
Something was moving when I started applying force, but it didn't seem to be the hub...�
-Paul
NEVER ever use a drum to pull a hub. As you have already found out the drum will deform before you have enough force to pull the hub. I have even seen one guy who managed to deform his drum so evenly that when he want to put it back on he didn't notice he had bent the center about 1/4 inch away from where it was originally, then he couldn't figure out how to get the drum back on as it was rubbing the backing plate.
Some guys make homemade pullers built from THICK metal that bolst up to the lugs, then have a piece of pipe with a threaded cap...a large FINE thread bolt is used in the center of the cap.. All made of at least 3/8 plate or 1/2 inch plate and schedule 40 pipe....and those also work at much less $$$ than the OTC ones. But you need access to a decent welder to make one. I cannot believe how spendy the OTC pullers have gotten...and I need to find one as my old one was stolen.. The KW one at $79 is fine for most guys once the initial pulling is done. It is those hubs that have not come off since 1949 that need a 5 legged puller.
I think we need to make a sticky FAQ tech post about pulling drums, as the most common first timer question we have is how to get the dang drums off.... There is a page about it on the site but.....do folks read it before trying?
One thing we must not forget to mention in any hub pulling discussion... ALWAYS THREAD THE LARGE NUT BACK ON A BIT BEFORE PULLING THE DRUM/HUB OFF...WHEN THEY FINALLY BREAK FREE IF THERE IS NOTHING TO STOP IT FLYING INTO YOUR BODY THEY WILL DO SOME SERIOUS DAMAGE!!!!!! Do not thread it all the way on , instead leave a space between the hub and the nut for it to move into when it does break free. This also protects the axles threads.
Bill--where is the FAQ on pulling hubs? I searched for one and couldn't find it.
I was actually thinking of getting some heavy plate (and I was thinking at least 5/8"), cutting the necessary holes to put the bolts through, and then using the puller I've got (in the picture at the top of the thread) to pull on that. Thoughts on that. (And this time I'll wait for a response before trying...)
BTW, I had no problem at all pulling the drums. Of the six I've removed (from the four axles I've got), they all came off by hand. On my tractor, the drums are reputed to be hard to get off, too, but mine came off with a couple taps of a hammer (with a block of wood in between, of course). I guess my good luck with removing drums is being compensated for with the hubs.
-Paul
Paul, if you use your puller with an acetylene torch to heat the hub it will pop off after a hammer blow on the end of the puller. I don't think your going to get it off without a lot of heat and you will probably have to get it a dull red before it comes loose.�
Paul,
What would the 5/8 plate buy you? Your pic shows that you can get to the hub with your puller, so where's the advantage?
My $.02 ..... Heat or time and penetrating oil.
Good luck, remember this is fun!
Zeke
Zeke, the advantage is that I wouldn't be bending the hub plate with the puller--which is what is happening now. The load would be spread out to the five bolts, which are at a smaller radius.
Like FBill said in his first response in this thread: "You might not want to hear this but I would shy away from that sort of puller on your hub. At the edge of the hub it has more leverage to bend the hub instead of pulling it. "
I tried the drum thing (which was a big mistake) because I was uncomfortable with the amount of deformation I was seeing in the hub when I was pulling like in the picture.
-Paul
Just popped out to the lab in the back where I work. There was a nice 8" diameter, 3/4" thick slice off the end of some round bar stock sitting on the scrap pile. The lab manager said he's not allowed to give anything away, but nobody would miss that piece. ;)
-Paul
It will be interesting to see if it will work..
How will you cut the center hole?
I would double check your wheel studs and make sure they are long enough for you to fit the 3/4" ring and the nuts, and then allow you to get the puller hooked behind...
I thought I'd try to drill/tap the hole to use the same bolt that the puller uses, so I wouldn't need the three jaws at all. But that bolt is 11/16-18, and I don't really want to bother trying to obtain that tap right now. (Funny, though, 'cause that's the second time in the last five years I've said that...)
My second thought was to drill it just large enough for the puller's bolt to slide through, and then tap it to a larger size at some later date (and obtain a bolt of the correct size).
But now that you mention it, I don't think that's going to work either, due to the clearance. I think the centre hole is going to have to be large enough for the axle and nut to fit inside. (I will have to check.) Is that too much for a hole saw to cut?
Is the metal disc you have just mild steel?� You might get through with a hole saw, but I'm thinking you might need to wear out a couple (maybe three) blades...
Do any of the auto parts stores near you have a tool lending/renting program? A couple of the chains like O'reillys lends tools....and how about an equipment rental place? The local one where I rent the engine hoist has pullers....
Pawn shops are a good place to look for used tools....
Good luck..
I'll find out if it's mild or not when I start drilling. I have to drill the five bolt holes in addition to cutting the centre hole...
Considering the source (the scrap pile where I work), there's a possibility it's not mild, but something like 4140. If so, I may be buying a whole bunch of drill bits as well as hole saws.
The idea of buying/borrowing/renting a puller starts to look more attractive, but there's something to be said for making one's own tools...
Thanks, Paul..... That makes sense. How are you doing with it?
Zeke
Look here� the one I built at first� the metal should be a little thicker
http://www.thecj2apage.com/forums/drums-how-to-remove_topic10055.html?KW=drum+puller
and
http://www.thecj2apage.com/forums/pulling-brake-hubs_topic64_post206.html?KW=hub+puller#206
So, I built the metal ring to be able to pull on all five bolts. Silly me, I made the centre hole big enough to go over a front hub, not realizing I wouldn't need a puller on the front... (A single hole saw actually did the job.)
Works well, in that I can pull really hard on it with my three jaw puller, without distorting the hub (the way I did when I used the 3 jaw puller directly.
But I still can't get the danged hubs off that old D44. (They popped nicely off the D41, though.) I was tightening the puller by standing on it, and still nothing.
So then I thought I could pull the axle shafts so maybe I could press the hubs off. Pulled the six bolts (on each side) that should hold the axles in (with the brake plate). And nothing. The axle shafts just won't come out. They shift back and forth a millimetre or so, but the won't come out. The ones on the D41--as well as the front shafts on the D25 and D27--just slid right out, with no force at all. What could be holding them in, and what can I do about it? If there's a C clip somewhere, I sure can't see it. (The D44 has a Powr Lok in it, if that makes a difference.)
-Paul
Well, I finally gave up and took the axle to an auto shop.
The axle shafts popped out quite easily with the big slide hammer. (I had considered buying one, but figured for one job it wouldn't be worth it.)
The hubs are a different story. The shop I went to didn't have one of the heavy duty pullers--and ended up stripping the threads on the puller they did have!
So, instead, they torched off the outer bearing races off the axles so at least we could get the brake backing plates off. (Those were the parts that I most wanted off that D44.) I will still put the axle shafts/hubs in my 20 ton press later to see if I can get the hubs off, though. With the axle shafts out, I should be able to get some penetrant into both sides, and let it sit for a few days first...
Finally got those hubs loose yesterday. Soaked the joints in ATF/Acetone for about a week, and then used a 20 ton shop press. I had to bear down on the jack handle with a good bit of force on the last couple strokes, so I'm guessing I was getting close to the 20 ton mark... When they came loose, it was like a gun going off.
-Paul
