3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: maximushuntermus on March 25, 2013, 11:46:58 PM
Where does this bolt to my clamp does not line up with anything could be wrong clamp think it came off a Hurricane motor any photos appreciated. Any tips anywhere on how to post my photos?
verbage got tangled up like I was drinking or something. My dipstick clamp doesn't appear to line up with any bolt holes and would appreciate a photo of where it goes.
It bolts to the lower left bolt hole of the oil filter bracket.
I suspected it had to be one of those however it seems like when I pry it over there, it makes the tube out of plumb, so it seems maybe the wrong clamp or something, it just doesn't reach, guess I will have to fabricate one couldn't find them online, least not yet. The bolt hole is maybe a 1/2" off the tube seems like it should be closer to an inch.
Mine holds the dipstick tube perfectly vertical. Can you post a picture of the clamp? I'll go take one of mine and post it up.
Ooops guess I still need to work on posting photos !!!!
I cut it down to 423 kbytes and it looked good but came thru all blurred out not sure whats up...
Here's mine.
(http://i748.photobucket.com/albums/xx125/willyscjmj/267F7A09-DA04-4B23-B671-FC7B977D7966-6929-0000116A421EA401-2.jpg)
I had this same issue on mine a little while ago and asked the same questions. I ended up finding the correct size clamp at a hardware store. A conduit clamp works very well.
Alright thanks again, my friends...
Hmm I'm pretty sure we never had that bracket, and inspection of a Packard flathead oiltube showed that the tube was pressed in place.
I took a nail and lightly dimpled the bottom edge maybe 3 times and knocked it in with a wood block. Maybe threw sealer on there as well.
-Jesse
Yes, the bottom is supposed to be a "press" type fit. The clamp just stabilizes the tube so it doesn't wobble around like mine does.
