3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: athawk11 on October 30, 2012, 08:44:16 PM
Hi all.
Winter project will be to restore my Carter WO and hopefully put my Solex into hybernation.
Can anyone tell me about the finish on the original Carter? � Can it be duplicated with modern products?
Below are photos of what I have to work with :
(http://i1195.photobucket.com/albums/aa397/athawk11/20121030001.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/20121030003.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/20121030008.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/20121030009.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/20121030004.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/20121030007.jpg)
It looks in pretty good shape to me. It should be easy to clean and rebuild and if the throttle shaft is not loose in the base then your good to go. I don't know if the Jeep carbs were painted or not but I have never seen a painted carb on any engines I have seen.
Get a NOS carb kit from Walcks.
Tim I have always thought the aluminum i.e. top of the carburetor was anodized due to the golden color, it reminds me of the color an aircraft baffle would be after it was anodized. And the bottom looks like black oxide or tool black would be a good match. Keep us posted on your progress. I have a carb I need to do.
Steve
Here's an interesting link for carb finishes. http://www.thecarburetorshop.com/Carburetorfinishes.htm
Here's another, http://wiki.answers.com/Q/What_material_are_carburetors_made_of
Here's another, http://reviews.ebay.com/ebaymotors/Carburetor-Body-Finishes?ugid=10000000004680950
Be careful how you treat the zinc/aluminum castings. You may do more damage than help.
Thanks for the responses and the links. Very interesting. I have seen the goldish color at the top, and the black in the throttle area that Steve mentions. At one time, mine appears to have had this finish. You can see the golden color in the crevises and in the mouth of the choke.
Per the links from Carl, it may be difficult to duplicate unless I want to spend big bucks $$$ on this rebuild. I just can't see having a Carb that cost more to fix up than my Willys did. I'll clean and polish it up the best I can and call it good. Bottom line, if it functions well, what difference will the finish really make?
Carl, I've read some of your old posts on Carbs. I've inspected this pretty closely. The throttle shaft is pretty tight. Less than 1/64" of play. The choke shaft has somewhere between 1/32" to 1/64" of play. Will this cause any issues while trying to dial in the Carb?
Although mine is pretty tight, I'm assuming that a loose throttle shaft would cause an air to fuel mixture issue.
Regarding the vendor, another good friend (Bedrock) thought Walcks was a good choice also. I will call them soon.
Sean on the 2a page replated his somehow, and if you search his posts for carb refinishing from a couple years back you might find the post...I don't think it was big bucks to do but it was tricky.
I don't think you will have any problem with that clearance on throttle shaft or choke shaft. Slight air leaks can be adjusted out with the idle bleed screw.
Be sure to ask for the NOS carb kit. It's a true Carter manufactured kit.
Today I used a Thermo Scientific XRF analyzer to test a carburetor. The top parts of the carburetor are made of zinc not aluminum. �
Steve
