3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: bretto on August 13, 2012, 12:56:59 PM
Title: Tank vent?
Post by: bretto on August 13, 2012, 12:56:59 PM
Coming from the M38 world, have a question regarding the 3A tank set up.  Was there a vent or vent line off the  fuel tank?  On a M38, they had the fording set up and had a tank vent line run from the tank thru the firewall to the aircleaner along with all the other vents from different assemblies.  Now with my set up, I do not have the fording set up but I'm trying to figure out where I should terminate the vent line.  Right now, it's in limbo just ending in the engine bay.  I'm just curious if the 3A had a system that would give me some ideas.  Or I'm open to suggestions to.
Brett
Title: Re: Tank vent?
Post by: Carls_jeep on August 13, 2012, 02:47:45 PM
I don't know about the rest of the CJ3A's but my tank is not vented, the fuel cap is vented.
Post by: F Bill on August 13, 2012, 03:10:49 PM
What does your tank have for connections?  Is it a 3A tank or a M 38 tank?  I would prefer a separately vented tank with a sealed cap, if I had the choice, but like Carl says, the 3A normally has only the cap vent.
Post by: bretto on August 13, 2012, 03:20:34 PM
Mine is a proper M38 tank with sealed filler cap and then a seperate vent line on the top that tank.
Post by: F Bill on August 13, 2012, 04:09:25 PM
I'd go with a M38 style vent line then... or go to avent line in the engine compartment somewhere with a filter on the end of it to keep the bugs out ....I take it your filler neck fits your tub already?
Post by: rocketeer on August 13, 2012, 05:18:38 PM
Just be aware, an M38 tank will not fit into a CJ3A without cutting a larger opening for the filler neck.
CJ2A/CJ3A
(http://cjsfs.com/wp-content/uploads/2012/07/CJ%20Jeep%20Parts%20for-sale-5715012905805719700.jpg)
M38
(http://justgastanks.com/images/649759.jpg)
Post by: aboyandhisdog on August 13, 2012, 05:31:15 PM
Brett,  I've got the same set up as you do.  An M38 with m38 tank with a vent in the top.  I don't have a line on it at all.  No need really but I see that it will accept some sort of line.  The cap does not vent.
Post by: bretto on August 13, 2012, 06:41:09 PM
Sorry if my post wasn't clear to all.
I do have an M38 vehicle, with a M38 tank.  The vent does not have a home in it's normal spot at the air cleaner.  It right now goes from the tank thru a line thru the firewall to nowhere.  I'm just trying to figure the best place to terminate it.  I thought maybe you guys might have an idea and thought that maybe the 3A had some sort of set up, I gather it doesn't.
Again sorry if I didn't clarify anything.
Thanks guys,
Brett
Post by: Carls_jeep on August 13, 2012, 11:33:08 PM
Well, considering your not going to want to go through water above the floor boards I would think the way it is would work.
Post by: calvinhunt on August 14, 2012, 12:30:18 AM
Like Carl says, just terminate it there in the engine compartment. �And like F Bill says, put something on the end to keep the bugs out. �Maybe a small breather could be purchased or make one from a piece of tubing filled with chore girl or similar mesh material and attach it to the vent line by use of a reducer.
I would rather have a vented tank than a vented cap!
Post by: bretto on August 14, 2012, 03:49:26 PM
Thought back to my R/C airplane days and remebered at one time I used a sintered brass clunk/tank filter. �I think I might give that a go.
(http://mediacdn.shopatron.com/media/mfg/101/product_image/a8cb6a21e7cb8a2b66101ae1a214637c.jpg)
Post by: calvinhunt on August 15, 2012, 10:44:49 AM
Good idea.  I've used such a filter before and believe it will work well.  The one I used was a water inlet filter for a furnace humidifier.  It was installed on a 1/4 inch water inlet line.  I'm guessing your vent line is that size.
