3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: Carls_jeep on July 25, 2012, 03:54:24 PM
Today I pulled the front pinion yoke and it was so tight I had to use heat and a strong puller with an impact wrench to get it off. Are they supposed to be that tight? The yokes on the transfer case were a nice slip fit. I will pull the rear pinion yoke tomorrow. I am replacing the seals and I have Speedie Sleeves ordered for the yokes. I bought the seals from Walcks a while back.
Carl,
My pinion yokes slipped off pretty easy. Perhaps this is true, because they leaked badly. I doubt they will be easy to pull the next time. I used Permatex 2 on the splines, in addition to new seals, to help stop the leaks.
Have you pulled them before?
It was harder than what I expected. I have a heavy duty puller and a strong impact wrench and it wouldn't budge until I hit it with the torch. I just tried to pull the rear yoke and it only moved about 1/4" with heat. I stopped and will try again tomorrow. I'm wondering if the last person that had them off used locktite on them. I have never seen one this hard on a car or pickup trk. I have had some hard to pull on road tractors.
I have never had them off before but in 60 years they may have been off a few times. I can understand them being a snug fit but this is ridiculous and I can't believe they come from the factory that tight.
I called Walcks today and he said they are usually easy to get off and sometimes he has to tap them off with a hammer and sometimes he has to use a puller but never had to use heat.
I guess mine were put on with locktite or something like that possibly to stop them from leaking. I got the rear one off today without using more heat. I did use a dimpled washer over the end of the shaft to keep from buggering the thread. The nut goes on easily on both pinions so nothing is damaged.
I have been trying to clean up the splines so the yokes go in a little easier.
Walcks ran out of head studs so I won't get them until next week. The engine is waiting.
I finally got my yokes on and the drive lines hooked up. I liked Jpet's yoke puller so much I made one like it. I also didn't want to drive the yoke on the pinion shaft so I made an installation tool, a threaded part to screw on the pinion shaft, a sleeve space and a nut to pull it on with.
Thanks again Jpet.
(http://i82.photobucket.com/albums/j276/yeathatshim/P8030013.jpg)
Just changed the seal in my rear differential. The most trouble I had was getting the nut to break loose. After I finally got the nut off, the yoke came off pretty easily.
