3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: macrisel on July 08, 2012, 09:24:06 PM
So I'm getting ready for paint, but waiting on my body man to get freed up. In the mean time, I'm fixing small things on the chassis that I skimmed over the first time around, thinking I could live with them or I had bigger fish to fry. Live and learn....
One of the things I'm working on now is the brake pedal play. From everyone's experience, is it usually the brake pedal or the cross shaft that is usually wore out causing play? Also, is is usually better to just replace the pedal or try and put a bushing in it?
Thanks guys!
Mark
Hey Mark,
If it's side to side play, it may be both the brake pedal arm and the cross shaft. I had...still have play on the brake after replacing the cross shaft. It is far less than it was. Still, it's a bit annoying. I've considered a sleeve or bushing also.
If you do that, post the process. I'd like to know how it turns out.
Well, I FINALLY got everything disassembled last night. I had to remove the brand new exhaust I had put on several month ago in order to get the cross shaft out. In my infinate wisdom, I had reeeeeaaaallly torqued the exhaust clamps down to avoid any exhaust leaks. This resulted in a great deal of curse words last night trying to get the (*&#@$(* exhaust split apart!
When I got the cross tube and brake arm out, both of them had wear on them. The cross tube has groves worn in it where the brake arm rides and the brake arm hole has been egged out pretty good also. It appears the pivot tube on the frame has been replaced sometime in the past and does not look too worn. The Bubba that replaced it not only bolted it to the frame, but ran a weld around it AND put a bead of weld on the nuts to keep them from backing out. Genius.... Anyway, I have already sandblasted and painted the frame so I'll probably leave it as it.
I considered only replacing the cross tube and putting a bushing in the brake arm but decided against it. I would have to drill out the brake arm, find a bushing and press it in, drill it out to match the cross tube, then drill the zert fitting in. While I know it can be done, I probably don't have the correct size drill bits and at this point I really don't have the time. A new brake arm from Walcks is $28 and I'll probably go that route. :-/
Like everything else, it always comes down to time and money. Do you ever reach a point in life where you have enough of both? :-?
If the link works, here's something BA over at the 3B page sent me for you to consider fabbing up. He used all thread and some washers to duplicate the fix Willys promoted back in the day.
http://i247.photobucket.com/albums/gg152/64_Surrey/1964%20Surrey%20Gala/23PEDAL_REPAIR1.jpg
http://i247.photobucket.com/albums/gg152/64_Surrey/1964%20Surrey%20Gala/P8310001.jpg
http://i247.photobucket.com/albums/gg152/64_Surrey/1964%20Surrey%20Gala/P8310005.jpg
Mac, I know what you mean about those exhaust pipes, I had the same issue when I removed my exhaust manifold last winter. When I put mine back on, instead of slipping them together again, I drove down to the muffler shop and had them weld on a couple of flanges to each end of the pipes so all I have to do in the future is unbolt them and they'll come right apart. Just a thought. If you weld you could do it for the cost of the flanges. It cost me $50 as I recall.
That is a great idea about the exhaust! While I have the exhaust off, I may have to really consider that!
I really considered using all thread to make my own fix, but decided to replace the parts instead.
NOTE: One thing to consider when using the replacement arm from Walcks. Install the arm and pedal and double check all your clearances before putting your exhaust back together and calling it done. I actually had to bend my replacement arm towards the motor a little bit to create some clearance. As it was, the brake pedal was rubbing against the steering tube.
