3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: F Bill on July 20, 2012, 06:29:54 PM
Gunslinger's post from the old forum
Gents,
I've got a bad squeak and some friction in my steering when I turn Right. It sounds like its coming from the top of the steering column right below the wheel, Any good ideas how to lube it? If I remember right there is a bearing at the top of the column, but I don't remember if I replaced it
Hey Gun,
When I rebuilt my Jeep a few years ago I installed a new repro upper steering column bearing. I didn't like the way it felt. Didn't squeak, but it did rattle and was loose/sloppy. I removed the steering wheel. I removed the NEW repro bearing. I dug out my old original bearing, cleaned it up and lubed it well. After installing it I was a lot happier. If you installed one of the worthless repro bearings you may want to do the same.
