3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: Quebec Jeep on July 05, 2012, 10:37:27 AM
I should have red old post about it before going forward and try to fix it. I learned it on the hard way.
So while trying to replace the knuckle seal...I found out that it's possible to get the axle shaft left/right front fall apart in your hand if you go too far away with the steering knuckle.
Now I know that I have bendix style joint on my jeep!
They are not looking too bad.
(http://pages.videotron.com/lavoip/index_files/Forum/BJ3.jpg)
But the front right one has broken spline. I'm also concerned with the mark and pinch on the axle.
(http://pages.videotron.com/lavoip/index_files/Forum/BJ1.jpg)
(http://pages.videotron.com/lavoip/index_files/Forum/BJ2.jpg)
What should I do? Replace it? Keep it? Try to find out the other piece in the differential?
I also have a broken yoke. It was already broken when I dismantled it so I think I will keep it like this and put back on my jeep. what do you think?
(http://pages.videotron.com/lavoip/index_files/Forum/Yoke1.jpg)
(http://pages.videotron.com/lavoip/index_files/Forum/Yoke2.jpg)
Pascal
How does the surface look where the seal runs. If its rough you can use a speedy sleeve or replace it. This is on the yoke.
That's only a small piece missing but it could cause centrifugal imbalance at highway speed. Buy a replacement yoke, they're not expensive. The only way I know to break one like that is to blow a u-joint.
I'll buy a new yoke.
Can I have a bendix style joint on one side an a spicer style on the other side? Or should I replace both for the same style?
Pascal
it must work ok, mine is like that. i will make it right one of these days. I think mine is a rezzepa and a bendix. I thought it was wierd my front drivers side lugs are 3/4 and the rest 11/16.
