3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: Shalka04 on May 23, 2012, 11:32:46 PM
Title: Fork in the road with my Rebuild
Post by: Shalka04 on May 23, 2012, 11:32:46 PM
First of let me say I know my T-90 is now Ford Blue, it's just that I wanted to be able to spot any sort of leak or drain, and the satin black of everything else just wasn't doing it for me.
So i'm at a pause trying to figure out what the next major step in my rebuild should be. �Do I install the tub next then the engine or engine now and tub later. �Then again does it even matter?
Thanks for your suggestions,
-John
(http://
http://www.pbase.com/shelka04/image/143538470/large.jpg
Title: Re: Fork in the road with my Rebuild
Post by: Carls_jeep on May 23, 2012, 11:43:18 PM
I would put everything I could on the frame before putting the tub on and that includes the steering box.
Post by: calvinhunt on May 24, 2012, 01:35:08 AM
I agree with Carl. �However, it's your Jeep and you can certainly assembly it as you like, but I would suggest installing the entire drive train and test driving it thoroughly before covering it all up with the tub and fenders. �Much easier to work on if you discover a problem. �
I installed brake lines and hoses, clamps, etc., before the engine was in the way. �
(http://i389.photobucket.com/albums/oo336/calvinhunt/Camera20078073.jpg)
Then the complete drivable rolling chassis was test driven for more than two hours before fitting the tub, fenders, grill, and hood.
(http://i389.photobucket.com/albums/oo336/calvinhunt/8Testdrive.jpg)
Then the tub, fenders, and all were completely assembled. �This allowed for all cutting, grinding, and welding to be done before painting. �
(http://i389.photobucket.com/albums/oo336/calvinhunt/JeepRebuildIII003.jpg)
That's the only way I learned that I had to modify the tub opening for the transmission.  Would have hated to do this after paint.
(http://i389.photobucket.com/albums/oo336/calvinhunt/JeepRebuildIII016.jpg)
After the test runs, body fitting, and painting, the final installation of the tub and other components took place.
(http://i389.photobucket.com/albums/oo336/calvinhunt/11FinalAssembly.jpg)
Post by: Ryan_M on May 24, 2012, 06:29:13 AM
I had to pull the transmission and the steering box several times after the initial "rolling chassis" test drives in order to chase leaks and other problems. It would have been a nightmare if the tub was on. As an added bonus, being able to actually drive the thing well before completion was a blast.
(http://i1188.photobucket.com/albums/z403/rmurdock2121/51%20Willys%20Jeep%20CJ3A%20Rehab/DSCN0655.jpg)
Post by: Carls_jeep on May 24, 2012, 11:23:28 AM
Calvin, your looking mighty sharp on that Hot Rod Jeep there fellow. ;) 8-)
Post by: macrisel on May 24, 2012, 03:21:12 PM
X4 with all the replies above.  If you have done ANY bodywork or used ANY reproduction parts, you are going to have to assemble everything to ensure a proper fit.
Also, you get some of the best looks when you drive around with nothing but a frame, motor/tranny and wheels  :o
Post by: BMIC on May 24, 2012, 04:02:07 PM
John great job so far... I kinda like that blue.
Post by: Gunslinger on May 24, 2012, 04:05:14 PM
I think a white skid plate with blue transimission mount and crossmemberr would add the "Patriotic touch"!!
Post by: CJPilot on May 24, 2012, 08:57:38 PM
John �You are certainly �moving along at a good clip! �Looks like you�ll be done in no time at all. �I plan on putting everyhing I can back on before I mount my tub.
Steve
1950 CJ3A
