3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: athawk11 on September 23, 2011, 08:51:30 PM
I didn't want to highjack Robertos tub work videos, so I started a different thread. �My chassis is done. �I started the engine. It started as if I never even took it apart. (Thank God).
Just some photos of what I have been working on. �
(http://i1195.photobucket.com/albums/aa397/athawk11/Tubunderside2.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/tubundersidesheetmetal20101231.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/tubunderside20110916.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/tubundersidegreen20110920.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/tubtopprimerfiller20110923.jpg)
Tub is almost done. �I have one more 320 sanding, then Gillespies Red Oxide, some 400 wet sanding, some Gillespies 23070, and I can start to reassemble this thing. �I still need to finish the fenders, windshield, grille and tailgate.
Looking good! Keep up the progress! ;)
very nice.....wanna trade??? ;D
Athaw11, no problem at all!!!! Cool shots! I have still a lot of work to do! Boufffff! :-/
Just curious: where have you got the new panels? Many thanks! And keep us informed.
That's some fantastic work there, are you planning to undercoat it too? have been figuring out if i want to undercoat then paint to protect it or try some of that rubberize coating then paint.
Seems like the best work comes out of a garage........... � ;) ;) ;)
Andy
Thanks for the kind words from all. �
Randy, though I know you're kidding, I'm sorry, I can't trade. �It's by no means perfect, but as much time as this tub took to get back to a decent condition, my wife would kill me. She's already * at me for the time spent in the garage. �If I would have know the total hours spent on the tub alone, I would have considered it a steel to pay $3000-$4000 for a new tub.
Roberto, I got the front floor pans ($65.00 each) and the tool box sides from Classic Enterprises and the hat channels from Midwest Millitary. �The links are below. ��I really wanted to do the rear pan too, but I just couldn't pull that trigger. �Too Much $$$. I opted to add additional hat supports to the rear pan to stiffen it up a bit. �
The web sites are: �http://www.classicent.com/jeep.php#4164 � �http://www.midwestmilitary.net/m38p12.html
The pans fit pretty well after some cutting and shaping the edges at the Transmission tunnel area. �The few extra inches came in handy as the rotten steel climbed up the tunnel edges.
Andy, I too thought about an undercoat. �But from what I read on the jeep sites, if you ever want to get it off for repairs, it's nearly impossible. �And there is a potential for hidden rust to develop, so I opted to coat the whole tub (and chassis) with Master Coat Silver. �A POR 15 kind of product with regard to its rust proof qualities, but unlike POR, the Master Coat can be sanded and painted using any top coat. �In the end, I really wanted the underside to match the top side. �
I am close now. �Have been wet sanding. If my wife let's me, I may be able to get the top coat on the tub this weekend. �Fingers crossed.� �
I totally understand, and yes I was kidding....very nice work sir....the wife thing I also understand..mine suggested a cigar box to keep track of my purchases for Beuhla...that lasted about the first or second order from Walcks...then I moved too a boot box....now I kinda got my eye on one of those Christmas tubs at Wallyworld.......maybe even two of them.....again beautiful work.
Fantastic work!
Nice work!
Good choice on the classic enterprises and midwest military stuff, I think most people wouldn't bother importing anything if they knew how good it was.
I like the added hat channel under the bed portion. I just spent the other night beating the crap out out my tub taking out the waves and thought they should have added more.
I hear you on the tub beating. �I spent hours and hours with a hammer and dolly. �The extra supports were a necessity on this tub. �There were areas that were pretty thin once the rust was removed. �I know it's not stock, but my choice was to replace the floor or stiffen the original floor. �
Thank you again for encouragement.
I wish I'd have read this thread before I ordered hat channels. I got mine from Classic for $185 shipped to TX. Looks like the Midwest kit is a little cheaper plus it includes the transmission tunnel hat channel. I'm still happy with the Classic Kit, its very good quality and the welds and craftsmanship look top notch. But I guess I should have gone with the Midwest kit. How does the welds and accuracy/alignment to the bottom of the tub look? My Classic hat channels line right up, but I wish they had the tunnel portion.
Midwest:
(http://www.midwestmilitary.net/m38channelkit.jpg)
Classic Ent:
(http://www.classicent.com/images/p7240005.jpg) (http://www.classicent.com/images/p7240005a.jpg)
Hey Comanche_County,
I actually had to weld the Midwest hat channels together. Thus the lower price I guess. They are pretty nice overall. They had the anti crush sleeves and threaded insert, thus I didn't have to put the wood back in. Measuring before welding was tedious, but I did want the transmission tunnel channel.
Hey there CC - did the channels from Classic fit well? I believe they had the crush sleeves in them as well? Were they also threaded?
What and where do you mean by a threaded insert?
Hey Bretto,
The hat channel that crosses directly below the gas tank has a threaded insert. The bolt is screwed up through the out rigger body mount and into the hat channel. This is the only mounting location that is done this way.
I am no pro, but probably a couple reasons for it. 1. A through bolt with a hex head under the gas tank is probably not desireable. It could rub and eventually cause a leak. 2. If you want or need to remove or lift the tub, you don't need to pull the gas tank to do it.
