3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: Gunslinger on April 19, 2011, 03:43:04 PM
Well I just want to say thanks for all the help you guys gave me onthe oil pressure issue, thought an update was in order. I pulled the motor out and took it apart, I found that the rear main seal was totally disintegrated and the pieces went into the crank and wiped out the rod and main bearings. That had to have happened right at start up cause the OP never did come up to where it belonged. I showed it to the guy that originally put it together, he said he had heard from the G503 guys that this can happen with some brands of seals. I'll check and make sure I get the right brand names before I post them. Looks like dejavue all over again. rebuild time. :o
I strongly suggest you use a rope rear seal for the crank. Your builder can do it easier than trying to get a rubber seal to work.
It's not the brand of seal that's the problem, it's the type of seal. There have been numerous posts about the problem on this forum, the CJ2A forum, and on the G503. Rule of thumb - replace the seal with what was in there originally; rope for rope, neoprene for neoprene. In your case I would go with a rope seal.
Ditto with the ripe seal. It took a second teardown to repair the damage that a neoprene seal did to my engine within the first 5 miles of driving it. Jim
I've got a rope seal for the real seal, couple of questions;
- how did you guys clean out the engine when you re-built it, I've got to get all the junk out from the bearings that disintegrated, any good ideas? i'm thinking i can wash the inside out with brake cleaner and wipe it down, and run the gun cleaning brush through the main gally, flush out the small gallies, would that be right?
- any tricks to putting in the rope seal? The crank is out and the motor is on the engine stand so i've got good access. Any ideas?
Pull all the oil galley plugs, crank and cam. Blow out all the passages until you think they are completely clean. Blow the crank oil passages out also.
I would replace any bearings unless they look like new or are not scored in any way. When a rear rubber seal seal fails it usually causes the rear main bearing to fail also from what I have read. That means the crank has to be turned or polished.
You push the rope seal into the slot for it and then roll it in with a piece of broom handle or large wooden dowel. Don't roll it in to tight, you want it to stick up enough to seal the crank. Trim the ends off with a razor blade about high enough you can feel it. If they are too high they can keep the main cap from seating completely against the block surface. Push the edges of the rope seal in towards the center of the rope so they don't get between the cap and block.
I haven't built a Jeep engine but it's like building any of the other engines I have built.
The only thing that surprised me was the Jeep engine only has one cam bushing and that's not good in my opinion.
I went the whole route, with align boring the block, and turned the crank mains down .020, installed all new bearings, and rope seal. �Jim
