3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: Paddy on March 15, 2011, 09:17:44 PM
Title: Rear Axle
Post by: Paddy on March 15, 2011, 09:17:44 PM
I've got myself into a corner tearing down my rear axle.  Got the drums off, no problem and was trying to get to the cup, cone and rollers, and oil seal, as they were leaking on both ends.  In the process of trying to remove the cup, I tore.  I mean tore it.  How the heck do you remove that?  The mechanics manual didn't do it for me.  Thanks.
Title: Re: Rear Axle
Post by: RussellL on March 15, 2011, 11:06:36 PM
I think folks are going to need a bit more info.  What is it that tore?  The seal?  The cup itself?  Can you post a picture?
Post by: Paddy on March 16, 2011, 08:11:27 AM
I wish I could post a picture but as yet I've not figured that aspect out.  I tore the cup trying to get the rollers and oil seal out.  The plan was to replace all of that at the end of the axle, put it back together and call it a day.
Post by: rocketeer on March 16, 2011, 09:15:40 AM
Did you remove the 6 bolts holding the retainer and brake backing plate on and remove the brakes?
http://www.vernco.com/RearAxle2/index.htm
(http://www.vernco.com/RearAxle2/b0f15df0.jpg)
(http://www.vernco.com/RearAxle2/b0915e50.jpg)
Post by: Carls_jeep on March 16, 2011, 09:16:56 AM
I was hoping someone who had removed a rear axle would help you, but alas, they have not.
I have a copy of the Willys Jeep Mechanics Manual and it describes in detail how to do it. If your manual is not a copy of the factory Jeep manual you need to get a copy.
You have to pull the brake drum and the brake backing plate off first and then you should be able to pull the axle and the bearing out together by grabbing it and pulling on it. You will have to get a hook type puller to get the seal out and have a correct size driver to install the new seal.
The Willys factory mechanics manual tells exactly how to do it. You can't TEAR a bearing outer race but you can damage it. You can TEAR up the seal removing it but that's ok. BUT, be careful, you can DESTROY a seal while installing it.
Post by: Paddy on March 16, 2011, 12:44:59 PM
If you look at the second picture (lower) picture above I'm down to the bearing and that metal ring is what I tore.  I can not figure out how to get it out in order to inspect the bearings.  I didn't mean to tear it but in the process of trying to "hook" it and pry it out I tore it.  I do have the mechanics manual which doesn't help me, at my level at least.  Telling me to use jeep tool 1234 doesn't quite work for me.  I was hoping that someone may be able to elaborate on the the photo above and tell me a tool name and how to approach it grabbing that little bugger in order to get to the inside.  Obviously at this point I know I'm going to have to replace what I've damaged.  Thanks.
Post by: Paddy on March 16, 2011, 12:48:15 PM
To be more clear in the second photo if you look at the red line from the word "roller bearing"  where that red line stops is what I tore.
Post by: Carls_jeep on March 16, 2011, 02:05:11 PM
Paddy, I don't see any photo's in your post. According to the manual when you pull the axle out the outer bearing race comes with the axle and the bearing on the axle. You can't remove the axle without removing the outer race at the same time.
The seal is a piece of sheet metal with rubber in it and that is inside or behind the seal. Is that what you tore?
Post by: Paddy on March 16, 2011, 02:47:55 PM
Rocketeer posted two photographs above, and in looking at his second photograph, I've removed the retainer and the bearing cup.  They are removed and with no problem.  My goal was to check the bearing and the seals and replace them.  This was my goal because (1) I figure after 60 years it can't hurt to replace the bearings, and (2) it was leaking oil out of the end of the axle.  I figure that can't be good let alone correct.  So, it was very easy to get to the point where everything was off the end of the axle, brake drum, backing plate, all very easy.  Once I got all that off there was a bunch of grease oozing out of the end of the axle at the point of what look like on the diagram in the mechanics manual as an oil seal and what is identified in Rocketeer's photo above as the roller bearing.  And when I look at it closely it appears there are bearings held captive in a metal race, and I tore the metal race trying to remove it.  If I knew how to post photos I attach one to make it clear.  But if you look at Rocketeer's above second photo where he identifies the roller bearing and imagine that metal ring torn, that's what I did, and now I'm trying to figure out how I remove and replace it.  And oh by the way, is replacing that bearing after 60 years a good idea or a bad idea given the fact that I'm tearing this thing down completely?
Post by: Tumbleweed on March 16, 2011, 03:48:34 PM
Did the bearings fall out as well? If so all you have left is inner ring of the bearing that is on the axle. The outer ring would have torn away and this is usually thin metal. If this is the case just use a puller to remove the ring off the axle.
Good luck,
George
Post by: Paddy on March 16, 2011, 04:28:12 PM
The bearings did not fall out.  I just tore the cage or race of the bearings, and I can't figure out a way to grab them with a puller.
Post by: Tumbleweed on March 16, 2011, 04:49:17 PM
A bearing splitter/puller will work if you can find a local auto parts house that has one for rent. I am in Ft Worth TX area and our Auto Zone auto parts has specialty tools that they rent for free. (as long as you bring it back!!!)
Just a side note: I have had no luck with posting pictures either. I think you have to have them on picture share program off the internet. It would be so easy to just drag or copy the jpg file into the forum but I think they don't allow this.
Hope the info helped a little. I am getting into rebuilding complete my 49 CJ3A and I'll have the same fun!
George
Post by: Tumbleweed on March 16, 2011, 04:51:55 PM
You can also send me an email and include jpg. of your axle bearing.
George
Post by: RussellL on March 16, 2011, 06:16:00 PM
If you tore the cage around the rollers, you just need to pull or pry or whatever you need to do, to finish ripping the cage off.  Once the cage and rollers are gone you will be able to see the inner race of the bearing and get a puller around it.
Post by: RussellL on March 16, 2011, 06:25:41 PM
I haven't personally pulled an axle bearing of these jeeps but, once the brakes and retainer are removed, can't you just pull on the axle and it will come out?  Bearings and all?  Or do you have to release something inside the differential?
Post by: rocketeer on March 16, 2011, 07:55:10 PM
I haven't personally pulled an axle bearing of these jeeps but, once the brakes and retainer are removed, can't you just pull on the axle and it will come out? �Bearings and all? ��
Yes, just grab ahold of the axle and pull and it will come out.
(http://www.vernco.com/RearAxle2/05a15cc0.jpg)
However, at this point, if the roller cage is busted the axles will have to be taken to a machine or auto shop to have the old ones pressed off the shaft and have the new ones pressed on. The damage is done.
I would suggest getting a manual. Do not attempt to reinstall the axles until you have read up on, and understand how to properly shim the retainers. Too tight and the bearings will burn, too loose and they will break.
(http://www.vernco.com/RearAxle2/06015c60.jpg)
(http://www.vernco.com/RearAxle2/06715df0.jpg)
