3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: Paddy on February 05, 2011, 10:40:46 AM
Title: Front wheels
Post by: Paddy on February 05, 2011, 10:40:46 AM
I'm stuck.  I can't figure out how to pull the front wheels off my 3A.  I got the rear wheels off with no problem by using a puller.  Now I'm on the front wheels and I can't figure it out, with the hubs. My puller doesn't fit over the wheel hubs to bolt onto the lugs in order to pull the drums, and I have a huge snap on wheel puller.  Do I have to disassemble the hubs?  I actually removed the screws that bolt into the hub through the drive flange but nothing easily comes loose and I don't want to force anything at this point as I'm unsure.  Any direction would be appreciated.
Title: Re: Front wheels
Post by: RA472A on February 05, 2011, 11:20:10 AM
The three screws you removed should allow the brake drum to come off IF the brakes are not hanging up.  Once the brake drum is off, you need a spindle socket to remove the spindle lock nut.  There will be a flat washer tab that is holding the outer lock nut in place and that will need to be bent down flat again to allow the spindle socket on.  from there, you should be able to see the washer, another lock nut, and then another washer that rides against the wheel bearing. all must be removed before removing the six bolts that holds the brake backing plate on.  Do you have a good manual?  Really helps for the step by step stuff from there on.
Post by: Paddy on February 05, 2011, 12:39:14 PM
Well I'm not sure what 3 screws you're talking about as I haven't removed a distinct set of 3 screws.  I was able to remove the drive flange and it's gasket, revealing the Nut.  What size is that nut as I don't have a socket or tool to fit it.
Post by: Carls_jeep on February 05, 2011, 02:33:43 PM
When I had my brake drum/hubs off to check things I don't remember screws holding the drum to the hub but there may be some. I thought the studs held the drum on the hub but I didn't look real hard because I pulled the whole thing to check and repack the bearings.
Well, anyway, the hub nut socket measures 2 1/16" that I got from Walck's.
Post by: Paddy on February 05, 2011, 05:47:22 PM
Wholly Shiite! 2 1/16 that's huge.  I'm assuming I don't go down to Auto Zone and pick that up.  Also I'm assuming that once I get that nut off I can pull the bearing and then the hub and drum pull off.  I have the mechanics manual but there's no step by step either in explanation or diagram.
Post by: Bob W on February 05, 2011, 06:54:10 PM
M38s have 3 screws that hold the drum to the outside of the hub. On a CJ-3A the drum is on the inside of the hub and will require removal of the hub to get the drum off.
Post by: Carls_jeep on February 05, 2011, 09:58:57 PM
There is a retainer washer between two nuts. Sometimes one part of the washer is bent over the outer nut to keep it from coming loose. You have to straighten the washer, remove the outer nut, remove the washer, remove the inner nut then pull the brake drum/hub off the spindle with your hands. The outer bearing will fall out of the hub and the inner bearing is held in place by the grease seal.
Lay the drum on a workbench and with a 1/2" dia. brass drift hit the inner bearing race and the seal and bearing will fall on the table. Wash the bearings in a solvent of choice and remove the grease from the hub and then wash it with a solvent. When everything is clean and grease free inspect the two races in the hub for pitting and the inner races of the inner and outer bearings for pitting.
If everything is good pack the bearings and there is a correct procedure for that. Put a liberal amount of grease in the hub and on the inner race lay the bearing in and drive the seal into the hub. Flip the drum/hub over and put the outer bearing in the hub. Clean the spindle and seal area and put a light coat of grease on the seal area.
PACKING A WHEEL BEARING: Clean your hands, put a dab of grease in the palm of one hand and with the other hand hold the bearing with the wide part facing the grease. Attack the edge of the dab of grease with the edge of the bearing in a manner that forces grease between the inner race and the retainer that holds the rollers in place. It takes a little practice and just using the very edge of the grease dab with repeated swipes and the grease will start coming out on the narrow side of the bearing. When that happens turn the bearing slightly and start on it again until grease comes out. Repeat that until the entire narrow side has grease coming out of it. You have to keep adding a little grease to your palm but don't get to big a dab or you will have a lot of trouble.
A LITTLE DAB'L DO IT.    BRILL CREAM   I just couldn't resist. ;D
THE BEARING IS NOW PACKED.
Slide the drum/hub on the spindle while you hold the outer bearing in the race as it goes on the spindle. Some put the drum/hub on without the outer bearing and then put the outer bearing in. Torque the inner nut to the spec in the book, install the washer and the outer nut and torque it and bend the tab.
Post by: Paddy on February 06, 2011, 12:34:44 PM
Thanks for the detail.  I've printed it off so when I get to it I can follow them.
Post by: jamesr on February 06, 2011, 08:45:52 PM
You probably can get it at Auto Zone.  they are usually hanging on the shelf where the brake tools, hardware etc. are.  They are a cheaply made socket, made just for wheel spindle nuts, for $10-$12 or less.  Jim
Post by: calvinhunt on February 07, 2011, 01:04:27 AM
When I took off my hubs and drums the first time I could see that the large nuts had been removed and reinstalled several times with a chisel and hammer. �It worked for me. �But the same day I order from Walcks all new hardware, including the needed 2 1/16 socket, four new nuts, the new washers, bearings, shims, etc. �When I installed them upon final assembly all the new hardware went on.
Post by: macrisel on February 07, 2011, 09:50:29 AM
My nut had been abused with a hammer and chisel also.  You can get them off like this, but really save yourself the time and headache and just get the correct socket and new hardware at Walcks.  Also, I would order a rear drum puller at the same time also.
Just a few of the many special tools you are about to aquire.  But look at it this way..you will already have the tools for the next Jeep you buy.   ;D
Post by: jamesr on February 07, 2011, 10:13:26 AM
Same here, someone used a hammer and chisle to remove/reinstall.  I got all new fparts and used a brake drum adjusting tool to pull the rear washers to the front and a drift punch to tap the front washer to the rear, then finished with the brake drum tool to bend them further down.  Worked for me.  Jim
