3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: brotherdavid on February 03, 2011, 05:48:32 PM
I was wondering how to run wiring for my 6 volt electric wiper motors. I'm going to run one on each side. I would like to make it look as good as possible. I know this is not stock but I'd rather have the electric motors.
I used the vacuum line as a "chase" for the wiper wiring. �Be sure your windshield frame has a good ground to the tub. �The pivot point of the windshield, and the hold down clips are not the best conductor for a ground. �Also, if your wiper motors are mounted on rubber vibration dampners, be sure to run a ground from the motor housing too. I actually formed a larger vacuum line so that I could pull a negative with the "+" voltage wire. �Most of "us" would see the difference in size, but most of "them" won't. My Willys is not "correct", but I have upgraded where it suits me, and my needs. Jim
