3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: macrisel on January 26, 2011, 09:10:36 AM
Can someone tell me how thick the "anti-squeak" strips under the gas tank should be? I'm thinking of making some out of rubber to reduce moisture retention..
The strips are 1/16" thick. You can see some surviving pieces here...
http://www.cj3a.info/tech/gastank.html
The strips were made from...
Asphalt saturated felt
Flintcoat 106
Armstrong Cork Co.
Sheathing Felt No. 314-47
I used 40 lb. roofing felt (paper). Cut the strips 3 inches wide, and folded them over 3 times, making them 1 in. wide, then cut the lengths. That makes them a bit wider, but did not seem to hurt anything. After the tank was installed and clamped down, I also wedged rolled towel in the voids between the tank sides, and tank end and the tub to keep dirt, rock, sand, limbs, sage brush and etc. out somewhat. Jim
Thanks guys! That really helps a lot and that is a good idea about the felt paper. I have some rubber strips that I believe will work.
Also, I didn't realize it until I saw the diagram, but it looks like I'm missing the bracket that holds down the rear of my tank. ::) Jeez.........looks like I'll get to try out Walcks new website again.. ;)
Mine was missing also, and Walks sells them pretty reasonably. Jim
