3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: bretto on December 09, 2010, 06:46:24 PM
So I'm stripping my M38 down with a 3A engine. I go to take off the intake/exhaust mannys together and after I undo all the bolts then slide of the assembly, I hear parts falling. There were, what I found, 3 washers or spacers that have the same size hole as the studs and about 3/16 thick. I put them back on exhaust thinking that is where they belong as there are 3 studs, but they seem too thick and I cant say I recall them there while I was undoing the nuts. And I cant see where else they would go. Any ideas?
Brett
Here's some info:
http://www.thecj2apage.com/forums/intake-exhaust-manifold-hardware_topic9997.html
(http://www.thecj2apage.com/forums/uploads/395/004.jpg)
I figured it out shortly after where they went. I was pleasantly surprised how easy all the hardware came off. I had dreaded the exhaust nuts, fearing breakage but after soaking for 2 days in PB Blaster, they came off just fine. I've only had 3 bolts so far break on my tear down and they were for the tub mounts. I'm hoping to pull the motor off the frame this weekend.
Brett
Do yourself a favor. When you put it back together, make sure you use some anit-seize on those nuts. That way they will also come off again in the future hopefully easily. Without anti-sieze, they can really fuse on tight due to the manifold exhaust heat. The large washer go to the studs where the intake and exhaust manifold share a stud.
