3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: Paddy on November 26, 2010, 10:39:10 PM
Title: Shock Absorber Washer
Post by: Paddy on November 26, 2010, 10:39:10 PM
I ordered two new rear shocks and 4 washers from Walck's for the rear of my '49 3A as they weren't present when I bought her.  Here's my problem how do you get the washer compressed tight enough against the rubber bushing in order to be able to drop the cotter pins in their respective holes?  It's as if the washer is about  twice as thick as it should be.  And is the washer necessary?
Thanks.
Title: Re: Shock Absorber Washer
Post by: calvinhunt on November 26, 2010, 11:50:15 PM
When I installed new shocks on my Jeep I ended up using all new cadmium plated, tempered steel alloy aircraft washers.  They are the same surface area and strength but thinner and lighter for aircraft use.  However, in helping other Jeep owners with shock installation I ground just a little from each rubber bushing face in order to obtain the desired dimension.  I used a table top disk sander.  A more readily available bench grinder will do nearly as well if you are careful.  The washer IS necessary to keep the cotter pin from cutting into the rubber bushing.  The washer evenly distributes the compression load against the cotter pin.
Other members will probably respond with different solutions.
Post by: Bob W on November 27, 2010, 08:02:53 AM
There is/was a special tool for compressing the bushing to install the cotter pin. I made up something by using a C-clamp and cutting slots in a short length of pipe. The pipe goes over the washer with the slots lined up on the cotter pin hole. Compress the bushing by tightening the clamp and then stick the cotter pin in through the slots. It's not ideal but it works.
Post by: jamesr on November 27, 2010, 09:56:43 AM
I did the same thing,using a C-clamp, but used a short length of .75" wide steel channel in lieu of the slotted pipe.  Now I get to do it again, because the contterpins I used were aluminum, not steel. I think I will try the slotted pipe trick this time.  Jim
Post by: Paddy on November 27, 2010, 06:37:02 PM
Thanks for the advice, I'll give it a shot.
Post by: Jesse on December 03, 2010, 02:24:46 PM
I took a pair of vice grips and set them so they were shut but loose on either side of the shaft that holds the shock absorber, and had my dad push the vice grips inwards twords the frame while I pushed the cotter pin in the hole.
Post by: rocketeer on December 03, 2010, 05:03:47 PM
Here's what the factory tool looks like:
(http://www.surfacezero.com/g503/data/500/medium/S53000121.JPG)
Here's a homemade rig using a pipe nipple slotted out and a C-clamp:
(http://i863.photobucket.com/albums/ab191/rocketeer_2010/Jeep/shock_tool.jpg)
Post by: Doug on December 04, 2010, 11:41:51 AM
Larry,  Your homemade tool looks like it would work better than the smaller factor tool.  Your homemade appears to allow more room to work.
Post by: rocketeer on December 04, 2010, 04:02:21 PM
Doug, it's not my tool but a photo from my archive of over 10,000 photos, although I do use something similar. �People who have used the factory version have never had good things to say about it. �:) �I've never used one but have always been wary of the short hook on the end. Looks too easy to twist the tool and have it pop off and bust your knuckle.
Post by: Jesse on December 04, 2010, 07:38:30 PM
Thats why I liked my method, it wasn't MY knuckles that would have gotten busted ;)
The C clamp does look like a pretty easy thing to make, I would use it if I ever take the shocks off.
Post by: Paddy on December 04, 2010, 10:29:58 PM
Rocketeer,
I get it.  The photo does the trick, beautifully simple.  I'll give it a shot.
