3A, 3B, DJ Technical Knowledge Base => "Modifications"-- Technical Questions, Answers, Incites => Topic started by: F Bill on June 05, 2013, 10:09:59 AM
Title: Turn signal Switches..
Post by: F Bill on June 05, 2013, 10:09:59 AM
Just a note to you guys doing turn signals.. Before we went on the road I got my helper to wire up a few signal switches we had lying around with a set of cheap blinkers on a board, as a beginner how to do wiring project. One thing we did discover, which some may not know, is that the turn signal switches out there are of several diffenent wiring schemes and operate in several ways.
There is the basic turn signal switch sold by many stores back in the 60's that used a whole new set of lights, front and rear. These were cheap, easy to wire up, and resulted in many classic cars having those darn lollipop lights mounted at each end.  All the turn signal switch did was operate the new lights, leaving the old lights stock. You do not want this style on your jeep, unless you do not mind extra lights
There is a light switch made by signal Stat that has a model number of either 800 or 900 on its case..It can be wired one of two ways. The one you want uses the single filament parking light bulb and flashes that single filament, leaving the other one lit or unlit depending on whether it is on or not.  There is also a second style that uses a two filament parking/turn signal  up front, which you will need to modify your present lights for.
The key to which you have is to look at the wiring. There are diagrams online, one has a parking light feed wire and one does not. (Both have brake light feeds and b + feeds)
These signals were used on all sorts of things, and can be taken off old school buses, older trucks with added signals, or if you are like me, bought off the internet from fellow jeepsters.
I'd recommend setting up a test with your new used signal, using some cheap trailer lights and wire nuts, to make sure it works correctly before you attempt to install it in a jeep. Of the three setups I got used from fellow jeepers, only ONE turned out useable, and it was the cheapest one I bought. The nicest looking one in a beautiful chrome housing turned out to be good for parts.
Also be aware some of these are set up for four way flashers and others are NOT. Most of the four way flasher ones have either an additional tab you pull out to operate them, or you pull the signal lever out to operate it.
Some also self cancel with a rubber wheel that rubs on the steering wheel. I don't care if that part works for my own jeep but it is a frequent failure part. Whether replacement wheels can be obtained I have not discovered yet.
Title: Re: Turn signal Switches..
Post by: Bob W on June 05, 2013, 09:32:34 PM
The Signal Stat 800 is good for our CJ-3As because it will flash the single filament front parking light. This turn signal switch also requires the front park light feed to be wired into it.
The Signal Stat 900 needs dual filament front bulbs and is wired up the more conventional way.
Post by: F Bill on June 06, 2013, 11:43:31 AM
I have two signal stat 800's, one wired up each way...So I probably have a 900 marked 800..
They seem to be pretty simple and easy to work on, if you get the right wiring diagram off the web they are easy to hook up, but testing with some test lights is a good plan to ensure it is actually wired right. Some of the wires on mine were close to the diagram, same color tracer or base color but the other color was off, etc.. but even a dyslexic dude like me was able to figger it out.
Post by: Uncle_Vin on June 17, 2013, 02:33:53 PM
Hate to ask, but could you post diagrams / instructions for each?  I'm a dummy when it comes to electical issues and I need all of the help that I can get.   :D
Post by: F Bill on June 18, 2013, 04:35:35 PM
Hate to ask, but could you post diagrams / instructions for each?� I'm a dummy when it comes to electical issues and I need all of the help that I can get.� �:D
I'll see what I can do.. The diagrams I used were posted on the Stovebolt Chevy site...but not entirely correct. I'm a few miles away from the switch right now but eventually I will be there to make our very own 3A page diagram...
Post by: malcomstrenko on June 18, 2013, 06:04:52 PM
hello all,  just want to chime in here that I'm wrestling with the turn signal wiring challenge and welcome any help or "direction" I want to make my Yankee Turnflex 730/6 work. Also have Spartan w/ self canceling wheel and a Signal Stat 900 "signalflare"  I'll keep watching    thx
Post by: F Bill on June 18, 2013, 11:00:46 PM
Be sure to check out this FAQ post for lots of links to the good info you need. until I get a chance to redo our very own wiring diagrams for the Signalstat 800 and 900 I have ..
Be aware tracer or wire colors for wires with tracers may be different on your switch than the diagram.
http://www.cj3apage.com/cgi-bin/yabb2/YaBB.pl?num=1362674123
