3A, 3B, DJ Technical Knowledge Base => "Original"-- Technical Questions, Answers, Observations => Topic started by: willem on December 07, 2017, 03:05:58 AM
need some help ,cj3a frame number
I am from Holland/Europe ,at the import inspection,of my cj3a 1951,they are telling me there should be a vin/frame rail code in the frame also ,I think it shouldn�t ,but were can i find any proof/documents that there is no number in the frame on a cj3a?
The body tag is there and looks legit ,i guess they think it�s not 100% original and somebody used another frame (i raised the the body 1 cm and used new bolds)
To be short,
1, any thing which says there is none ,and there should not be a number on a original cj3a frame ,
ore
2. I need a number on the frame witch says it�s the cj3a frame
This is driving me nuts because I won�t get a license plate and can�t drive it
To my knowledge a CJ3A has no frame number ,tried mr google images surge and did not find any cj3a frame numbers
Double check with Bob W, but 1951 3A certainly did not have a frame number.
I expect the reason was because those frames were factory built and not outsourced.
You might find this close related information to be helpful....
http://cj3b.info/SerialNos/SerialNosFrame.html
Willem,
I looked at Bob Westerman's book "The Civilian Jeep Model CJ3A" and on page 3, it states:
"Unlike many other Jeep models, CJ-3A's did not have frame numbers...."
Bob W's book references tons of Willys factory documents and, in my opinion, is considered very technically accurate.
Willem,
this is great info ,thanks allot :D
You might find this close related information� to be helpful....
copy paste to the inspector of the RDW ,good info guys thanks
I can�t get an book here in time if I order it , but without telling anyone can anyone send me a copy of that page pls? i can email him ;) :-X w2w@kpnmail.nl
Will any of this help?..Info from the Home page....
http://www.cj3apage.com/index/Tech_Tips/dating_a_cj.htm
http://www.cj3apage.com/index/Tech_Tips/Production.htm
thats writen by bob westerman ::) nothing about a the non excisting number on the frame great info though thanks
but ,somebody on facebook send me a copy of a page of his book :-X were it says "no cj3a left the factory with an frame number"
i have send it to the inspector , now i am waiting for an answer :-? ::)
Here is page 3.
http://www.cj3a.info/temp/pp3.pdf
Here is page 3.
didn't rialize you own this page ::)
This Forum and website are member owned. My website has a slightly different name.
