TECH FAQ SECTIONS => Engine compartment => Topic started by: Tumbleweed on May 03, 2016, 09:42:32 PM
I decided to go with a single pump fuel pump on my 3A. The first pump I got from RockAuto was an Airtex pump. Immediately I knew the this pump was defective since the top bolt holding the diaphragm cover was not seating properly. I think they must have drilled it at a slight angle causing a massive leak at the top cover when I cranked the engine over.
I returned it about a week ago and today I got my new pump. Everything looked good until I turned the engine over and gas squirted out both weep holes. This is an indication that the diaphragm internally is leaking. Now I'm getting frosted! This is the last time I buy Airtex fuel pumps. I think Scoutpilot has some pumps for sale. I'm going to call him tomorrow.
Buyer beware!
[size=12]I am no fan of the vintage �clones�. Airtex, and all the rest started off with the original design and construction, but quickly moved to cheaper methods of production with cheaper parts. A machine can install press-in valves without screw plates that need a human to twist the screws. Planned obsolescence began post-war. [/size][/b]
[size=12]My Airtex fuel pump started to leak soon after it was installed. I had to take it apart and make a new gasket for it. I think the ethanol in our gasoline caused my problem. It seems fine now.[/size]
Scoutpilot's fuel pump is working great. I got a full return for my defective Airtex pumps.
