Rambling, Malarky, Rants, Etc. => Rambling, Malarky, Rants, Etc... => Topic started by: athawk11 on September 08, 2015, 03:42:47 PM
Title: Idiot...Not This Time!
Post by: athawk11 on September 08, 2015, 03:42:47 PM
Many times I come here to report my failures and poor decisions.  All with the hope that I will help 3A folks avoid following in my footsteps.  When I do this, I hope my humility shines through with the words I choose.
 Today is not that day.  I made a decision that I want to bask in for a moment. (These moments are generally few�and far between.)
I wanted to replace the brake drums on my rear axle.  (I deformed them while using the wrong style puller)  I will always try to do a task like this with what I happen to have lying around.  I have read stories that point out the challenges people have when trying to remove the hub from the drum, but I still figured I could just add some heat and beat or cut the studs loose.  I figured it would be an �all day affair�.
That�s when I finally wised up.  Instead of beating the crap out of my hubs�and myself, I bought the 12 ton press from Harbor Freight.  $129.00 +Tax.   After press assembly, I had both hubs off the old drums in about 10 minutes.  I was so excited, I think I may have actually jumped for joy.  I cleaned up the hubs then pressed in new studs to lock the hubs back on the new drums.
There you have it.  Finally, a smart decision to share.
Title: Re: Idiot...Not This Time!
Post by: JeepFever on September 09, 2015, 12:33:48 AM
Not sure why,  but I was expecting a traffic story, based on the title.   ;D
Yeah,  I bought one of the cheap presses years ago, and it sure has save a lot of aggravation at times.
Post by: RICKG on September 09, 2015, 09:49:26 AM
Thanks Timhawk.. I actually was looking at THAT press a couple weekends ago and wondered if I could justify the purchase or if I would ever use it.. now you got me re-thinking it..
Post by: macrisel on September 09, 2015, 11:01:01 AM
I also broke down about a year ago and bought a cheap press.  While I would not use if for everyday use, those 1 or 2 times a years you need it are great.
Pressing out the bushings on the front suspension of my '59 was a snap and I was done in 10-15 minutes.....including pressing the new bushings in!
Post by: scoutpilot on September 09, 2015, 11:55:50 AM
[size=12]I just used mine day before yesterday. My son (Muskrat) needed to change out his F-350's drive shaft carrier bearing. Saved a lot of hassle and time popping the yoke and the bearing off the short shaft separately. [/size][/b]
Post by: Ryan_M on September 09, 2015, 04:55:08 PM
I bought the same cheap HF press last year. Although I don't use it a lot, it has definitely paid for itself in "parts I didn't damage using an inferior method" (including removing a hub from a brake drum). You'll wonder how you ever survived without it.
