Rambling, Malarky, Rants, Etc. => Rambling, Malarky, Rants, Etc... => Topic started by: athawk11 on July 27, 2015, 11:49:33 PM
Just wanted to share some pain with my Willys brethren.�
I've been chasing a rear main leak for some time now. I've done the Sneaky Pete approach 3 times in this year alone.� With little success, I've finally pulled the trigger...and pulled the engine.
(http://i1195.photobucket.com/albums/aa397/athawk11/20150711_180954_zpsyjbzecey.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/20150712_105748_zpserhluc3w.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/20150712_110951_zpspizlxtnq.jpg)
(http://i1195.photobucket.com/albums/aa397/athawk11/20150712_114705_zps0cyplpkg.jpg)
While out, I also decided to do a ring job.� I found broken top rings on #3 and #4 pistons.
This is a 1944 GPW engine that was probably sold to a parts house by Ford following the end of WWII.� It has never had a rebuild.� It still has standard size pistons and the crank and rod journals are still within spec.� I have no idea when this engine was replaced, thus no clue how many miles it has on it.� My guess is, very few.� Since under my control, it has about 4000 miles added to it.
I've done most of the repairs and I'm nearly ready to put it back in.� Pulling an engine is a lot of work.� No wonder I tried to avoid it.
[size=12]I will commiserate with you. Two motors out and two in in two years.[/size][/b]
Hey Tim, I am curious, what did you have for compression on #3 and 4?
Glen
Hi Tim, How did you know those rings were broken?
Also, how did the seal install go? What could you do with the engine out that you couldn't do before? You used that same rope seal?
Rick, I have been following your engine issues. I know you feel my pain�and it�s my pain on steroids.
Glen, The last time I checked was last year before the FCT. Compression was in the High 70s, so I knew something was a little tired.
Tom, I really didn�t know I had broken rings until I pulled the pistons. Because of my low compression readings along with a leak down test, I made a semi�non--educated guess that they were worn or broken.
The seal installation went well. I am using the rope seal.
The disadvantage you have when installing the seal with the engine in place� You need to pull the new seal over the crank shaft. This is difficult enough because the Sneaky Pete style tools don�t work very well. Added to this, you�re on your back with poor lighting, and very little space to maneuver. It�s nearly impossible to cut the seal to the proper length once you have it pulled over the crank. And through it all, you have oil constantly dripping on your face.
The advantage to doing the seal without the crankshaft in the way�You can properly pack the seal in the channel and you have added room to cut the seal to the correct length.
Again, I was willing to try the Sneaky Pete approach because of the added effort required to pull the engine. But as you know from the SDR, I was embarrassed by this failure�plus I�m tired of wiping the oil splash back from the underside of my Willys. I don't mind wiping the mud and dirt off. It comes off way easier than oil. ;)
Tim, your broken rings concern me, inspect your ring grooves carefully. I have seen this before, I have found the ring grooves in the piston to be worn (top to bottom of the groove).
Good luck with repairs, Lee ;)
Lee, I did inspect them after cleaning them. They looked to be crisp and had sharp edges, but I didn't measure them. The #2 ring was interesting though. It was a three part ring. I haven't seen rings like this before. No, I'm not confusing it with the #3 ring. It was a traditional 3 part set up. I haven't seen a ton of rings, so maybe this isn't that unusual. This was the combination found in the #2 position.
(http://i1195.photobucket.com/albums/aa397/athawk11/20150728_214904_zpsxrvbxctv.jpg)
Engine is back in.
Initial test start... Running like a Swiss watch. I'm tuckered out for tonight, but tomorrow I'll reinstall the grill, then take it for a run to see if the rear main leaks. I'm in a freakin good mood! :)
cool [smiley=thumbsup.gif]
Wow...Tim you are the enginemiester...and transmissions too..
� I'm in a freakin good mood! :)
Me too pal!!
Lol Tim. I know how I feel after I do an oil change or R&R an e-brake cable...I can just only imagine how happy you must feel right now. If I had half the talent you do, I would die one happy camper!
That said, don't get bummed if/when a drip comes back. I think that is just the nature of the flatfender.
Thanks for the encouragement my friends! :)
Tom, I expect some dripping...just hoping it's not torrential like it was in South Dakota. :-[
You are talking Model A stuff here! Actually I have yet to find a single gasket between the engine and transmission....
Glad you got your rig back together again. I believe that these Jeeps will test your patience for sure! Once you get rolling and that cool air blowing through your hair your frustrations will disappear!
The shake down run had its ups and downs last night.
The good...The engine performed very well. I have more high speed power. The major leak is gone.
The bad... The brand new throw out bearing squeals and squawks. >:(
Will this pain never end?
After the test runs, I ended up having a setback. The brand new throw out bearing squeaked and squawked. I pulled it back apart and fixed the issue. All seems well now.
For me, 2015 will go down as a very bad year for Willys repairs and maintenance. I've had very little windshield time. :-[
Ain't it all fun though! Are your hands are permanently tattooed with oil and grease?
Tim, we'll remedy the windshield time deficiency at the FCT......
Tim, I feel your pain. The worst summer for me too. Last week the red rascal could have burned up along with my garage. The result is that now it is getting a new starter, an alternator to replace my generator, new oil lines and I have to move the oil filter. Among other items. The fun just never seems to end. Hoping I can still afford to get down to the FCT. ;)
What was the issue with the throw out bearing?
Hang in there Tim,
Almost FCT time and I'll bring you a cold Shiner Bock!
Sounds good George! I'll hold you to that.
Rick, after all this effort, I'm considering bringing my 2A to the FCT this year. It's a mess, but might be fun...and challenging. It runs. It has new brakes. It shifts. But otherwise, it's a disaster. ;D
Tom, I did read about your electrical issue. I wasn't sure I would be any help, so I let the sleeping dog lye. The only similar issue I had was a "smoked and burned" wire from the starter solenoid to the ammeter. My ammeter lost its insulation around the combination mounting posts/wire terminals. That was ugly, so I knew how you were feeling, but the wires that fried were different from your experience.
The new throw out bearing needed to be "packed" with grease. After the fact, I learned from Oilleaker that he will always pack a new throw out. I just didn't think a new bearing needed this effort. Ya Live...Ya Learn. ::)
Well, that Mr. Leaker is one crafty fellow!
You should bring Whitey to the FCT. Give her a taste of what the future holds.
I'm putting in one of those mini racing starters right now - just came in the mail. It's about as big as a grapefruit, crazy!
If all goes well in Dillon with "Or" my '51 M38 you saw sitting in the garage, I'm breaking him in good at the FCT. I didn't build him to just sit and collect dust. He drives like a brand new sofa sleeper. Might be too easy huh? Oilly
Congrats on the success. I know that leak was frustrating for you in SD. Working on them can be fun, but not so much when you are going back in and redoing something you already did :S. Driving them is more fun :). Cya in CO.
Thanks Jpet. I appreciate it.
That is the rub. Working hard to solve a problem, but still coming up short. I just remind myself that the failures are all learning experiences.
See ya soon!
See ya soon!
Your mindset is incredible Tim.. Me I cuss a lot then blame the Dog! see ya @ FCT.
See ya soon!
Laughed out loud Rick! ;D
One of my favorite Churchill quotes, "Success consists of going from failure to failure without loss of enthusiasm". Keep the ball rolling Tim....
Excellent quote. :)
