Rambling, Malarky, Rants, Etc. => Rambling, Malarky, Rants, Etc... => Topic started by: garage gnome on December 17, 2013, 06:49:43 PM
Thinking about what I want to do with the fitty-five Chevy. I have access to a set of 4.57 gears for the original rear end. If I do decide to make it 4wd, I can get 4.56 gears for the K20's front axle.
Will the .01 difference be a problem if I use the 4wd?
No.
That's more than the difference you'll get with unequally worn tires.
If you want to be a math fanatic, you're doing it the right way, putting the deeper gears in the back so the front axle will be pulling a bit compared to the rear.
But
In reality the difference is so small the tires will swamp it.
Ok, thanks!
Most of the factory 4x4 vehicles have that or more of a difference between the front and rear
Yep. A lot of examples including the D25/D44 4.09/4.10 sets. Is the rear axle on that the drop-out style? I didn't have too good a luck with those not spitting gear teeth out on the street. On the flip side, very easy to set up.
Nate, what are your plans for the rest of it? I would very much like to build a 46 3/4 ton Chev using my present 3B engine, SM 465, and NP 203/205 doubled T case. Probably just going to use D44/D60 axles under it but maybe 60's on both ends.
If drop out style means that the yoke and carrier all come out in one piece like a ford 9" rear, then yes.
So far it consist of a 350 sbc, 700r4, NP208, stock rear axle, and the K20 front axle (GM 10 bolt). I don't need a radical 4x4. I just want to build it into one and use it to bring engines to engine shows and maybe do a little drag racing... :o I know, 4.56s are probably not the best gear choice, but it will get off the line fast and with the overdrive, it will have a final ratio of 3.12 which isn't horrible. And if I add a super charger... ;)
Look for a set of CUCV axles any of the pickups will have 4.56 front and rear, most have a least a rear locker.
