Your Projects => Your CJ-3A Project => Topic started by: mtnman37879 on March 27, 2017, 12:26:34 PM
Title: One Owner CJ3A Restoration
Post by: mtnman37879 on March 27, 2017, 12:26:34 PM
Well, I finally got her home and sorted. This project was started by another member here and I bought her a few weeks ago. Lucy is basically a one owner machine (even though 3 people owner her before me). She was purchased new in 1950 by Eddy Arnold, a Country singer from the Grand Ole Opry. She was used on his farm in Tennessee. He sold her in 1986. The next buyer used her in parades for a bit, then she was parked. The next owner took her home and parked her for another 8-9 years then he disassembled her and did some repairs on the frame and painted the frame. Then I bought her. So far she's never been out of the state of Tennessee!
� It amazes me as to how good the condition is. The bell crank feels like new, as do the tie rod ends once you get the years of grease off. The steering box has been dissembled but the oil still leaks from the box. The engine has been replaced with a Jasper rebuild at some time and it is a Kaiser Supersonic. Look at the pictures, the labels on the side of the block are paper warning labels. How long do paper labels last? I have receipts that show a generator rebuild and a starter rebuild. The dash is almost unadulterated, just a couple of screw holes, easy patch. The Gauges look stock and the speedo shows 89,000 miles. The seat frames are still factory black.
� �All those plastic bags on the wall are the parts the previous owner removed and labeled. She also has the original heater.
� The worst part seems to be the floor but it's very fixable. The body on the passenger side needs some attention but once again an easy fix.� �
� Lucy has her original Willys soft doors(in great condition) and the frame for the soft top(the top was too deteriorated to save).
� Fenders and grill are fine. Tailgate has some rust in the bottom roll but it's fixable.
� I almost think some paint stripper would bring her back to original paint. She's Luxon Red, I think that's the name, it's almost maroon. The wheels seem to be Cream under the green. I'll be repaint her to the original color scheme(or as close as possible).
� Here's some pictures:
Title: Re: One Owner CJ3A Restoration
Post by: aboyandhisdog on March 27, 2017, 01:27:19 PM
Pretty sweet!  Don't get Flamingo * all over your work.  Did the PO say that the engine is still strong?  Do you need to dive into the drive train, or doing mostly frame/body work?  Good looking project!
Post by: mtnman37879 on March 27, 2017, 01:42:01 PM
Pretty sweet!� Don't get Flamingo * all over your work.� Did the PO say that the engine is still strong?� Do you need to dive into the drive train, or doing mostly frame/body work?� Good looking project!
In the next few days I'll hook a oil pressure gauge to her and fire her up to see what kind of pressure I have. Then I'll do a compression test. If it all comes back acceptable I'll replace the head gasket and front and rear main seals(all easy while engine is out), paint it and call it good. She'll get a new clutch too. I've yet to open the trans to see what it might need.
  Plastic Flamingos=Plastic *! Easy to clean!
Post by: Kirkski on March 27, 2017, 05:20:19 PM
Sweet project, are you saying this is the same Jeep as in this picture?
Post by: mtnman37879 on March 27, 2017, 06:56:02 PM
Yes, that's her. I also have the original title, signed by Eddy Arnold, Copies of the letter written by Arnold requesting a lost title so the original could be kept for posterity.  original owners manual signed and dated when he sold the jeep, Several other pictures of her life, some miscellaneous receipts and a bunch of registration papers from the Arnold days. Maybe if I ever sell her this will increase the price.
Post by: Kirkski on March 29, 2017, 08:21:57 AM
mtnman37879 that is really cool, my mom was a real Eddy Arnold fan, looking forward to this restoration!
Post by: mtnman37879 on March 31, 2017, 11:10:06 PM
The postman was very good to me today! Bearings, seals and hubs. When I cleaned up the rear hubs I found both were cracked at the keyway.� I got these NOS hubs from the guy in Chickamauga. They're both left hand but I got lucky they both have studs, the one in the picture had no studs. I'll replace one side with right hand studs. Axle bearings from Rockauto and rebuild set for the third member from some jeep place on ebay, $84 for the set with shims, seal and cover bolts. All Timken bearings. The rear was apart when I got her so I'm rebuilding her. The old bearings were worn but not worn out.
Post by: mtnman37879 on April 02, 2017, 01:15:33 PM
Reassembled the rear axle today. First try and the cut is as good as it gets! Next step get some paint on it and get it on the springs.
Post by: mtnman37879 on April 11, 2017, 05:47:35 PM
Once again the postman was nice! Four 11" brake drums, 4 wheel cylinders, 4 sets of shoes, 4 parts kits, all the U bolts and all the shackles and all the bolts for the springs and all 4 springs. Now if the durn backing plates would get here I could assemble it all. Work progressing nicely.
Post by: mtnman37879 on April 26, 2017, 11:13:05 AM
The view from the bottom. Not as bad as a lot of Jeeps I've seen. Lots of unfaded Luzon Red under that grime. Who has the least expensive Hat Channels?
Post by: RICKG on April 26, 2017, 04:55:30 PM
UGG.. Bodywork..
Post by: Kirkski on April 26, 2017, 05:34:02 PM
I was VERY happy with all of the materials I purchased from Classic Enterprises... everything was as it should have been. I got hat channel, floor pans, side panels and rear pan no issues
Post by: athawk11 on April 26, 2017, 10:33:33 PM
I've bought a couple sets of these.� Very nice, and a decent price.
http://store.midwestmilitary.com/product-p/mwm134.htm
Note: some assembly required. ;)
Post by: mtnman37879 on April 27, 2017, 12:01:12 AM
I ran across these tonight. I can measure, cut drill and weld I hate welding galvanized but I have done it. I think I could hit the weld areas with a grinder first and all will be good. Another plus, rust free. http://www.clarkdietrich.com/products/drywall-framing/furring-channel-hat-channel
Post by: SteveW on June 05, 2017, 07:39:25 AM
Nice history ,my Dad was born in western Tenn. (Brace) near Lawrenceburg. I got my repair stuff from Classic Ent also. That hat channel you found for construction is very flimsy not really structural usage. I am an electrical contractor and beat,curt and flatten it all the time.
Post by: mtnman37879 on June 23, 2017, 09:58:27 AM
I haven't posted in a while still recovering from Major Surgery. Here's some pictures, The steering box awaiting a new sector shaft. It should be in the mail today, a Crown part from Quarter Ton And Military.� The shaft had very little wear but it was twisted at the splines. The box is getting a complete rebuild, bearings, seals, horn button and wheel.
Post by: mtnman37879 on June 24, 2017, 07:50:40 PM
Steering box complete! New bearings, bushings, and sector shaft, a complete rebuild. Steers like a new one. The sector shaft wasn't too worn but it had a twist at the splines.
Post by: mtnman37879 on August 30, 2017, 12:04:06 PM
Been working on the wheels, I had four and I bought one more for the spare. The spare was dated 1947 but the four that came with the Jeep were all dated 1950, the year of the Jeep, original wheels. In the picture the one on the floor on the left is what the fronts looked like, the middle one is the rear view and the right side one is cleaned and ready for paint. The two red ones are complete. Regal Red is the color that they will be. The Jeeps body will be Black.
Post by: 1955CJ-5 on August 30, 2017, 01:15:06 PM
They look great.....after many paint samples I also decided Regal Red looked the best...
I let them bake in the sun after painting....right or wrong they have held up well....
Post by: Kirkski on September 06, 2017, 01:17:06 PM
Nice Job
Post by: mtnman37879 on September 07, 2017, 04:52:47 PM
The wheels are done, now to let the paint cure for a couple of weeks then it's off to the tire shop to have the tires mounted! The four wheels that came on the Jeep are dated 1950, original wheels. The fifth I bought for the spare and it's a 1947.
Post by: 1955CJ-5 on September 07, 2017, 07:11:04 PM
Those look great, and should really look good with the black body color..I almost bought Traxions....in fact I ordered Traxions and immediately called back and changed to NDCC's...
Are yours 15" or 16"? Mine are 15's and were most likely original..
Post by: mtnman37879 on September 08, 2017, 07:23:14 AM
Mine are 16" and came from the factory with them. Everything about this jeep is still factory original. A rare find.
Post by: athawk11 on September 08, 2017, 01:34:00 PM
Is there anything in the historical documentation that mentions an engine replacement at some point?
Post by: mtnman37879 on September 08, 2017, 06:48:26 PM
No, but the engine has been changed. It now has a Kaiser Supersonic engine and It's a Jasper rebuild. The warning tags from Jasper are still on the engine.
Post by: mtnman37879 on September 13, 2017, 04:21:22 PM
The rear end is complete and ready for paint. New bearings, seals and hubs. Also added 11" brakes.
Post by: mtnman37879 on November 10, 2017, 11:42:02 PM
I've been busy on the 1950 for the last couple of weeks. Getting a lot done. New floors, hat channels, several body panels and some reinforcements. The tub's getting close to primer.
Post by: mtnman37879 on March 22, 2018, 05:17:21 PM
Some assembly required! This is the front axle of my 1950 CJ3A. Every surface has been cleaned and inspected. Every hole has been tapped and every thread has been chased. The balls have been polished and everything that should be painted has been primed. The spindles have been re-bushed and the nuts have been renewed. The axles had oil seal wear grooves, those have been sleeved. The lockouts have been cleaned and the bearings will be replaced. Now for the assembly! Soon she'll be getting a paint job, the final step.
Post by: mtnman37879 on April 13, 2018, 09:59:15 PM
Got a bunch more work done. The axles are ready to install. Every bearing, and every seal have been replaced. All the clearances have been set, both front and rear gear sets are cutting almost perfectly. 11" brake backing plates installed. Painted and ready to hang under the frame.
Post by: MGYs on April 14, 2018, 02:16:19 AM
Thanks for sharing those pictures! You helped me in that I couldn't remember how the rear brake line T-fitting was installed, so I fabricated an L bracket. Then I saw your rear axle pic. Now I know where that piece I was holding in my hand the other day is supposed to go! [smiley=2vrolijk_08.gif]
Please let me return the favor (or possibly cause you grief, for which I apologize in advance). On my front axle, I had the following tags.
Post by: MGYs on April 14, 2018, 02:21:24 AM
Bendix tags
Post by: mtnman37879 on April 14, 2018, 06:11:09 AM
My front has Spicer axles so here's the tag.
Post by: athawk11 on April 14, 2018, 09:15:08 AM
Looks good.  I noticed the EP 140 gear oil in your photo.  Original spec calls for 90w.
Post by: mtnman37879 on April 14, 2018, 12:26:00 PM
Looks good.� I noticed the EP 140 gear oil in your photo.� Original spec calls for 90w.
Yep, that's what my Service Manual says too. I think they owned shares in the company that made 90w cause you pour it in constantly. The 140 stays put.
Post by: mtnman37879 on April 19, 2018, 12:52:45 PM
It's finally starting to look like a Jeep instead of a large pile of parts. The front and rear axles are installed!
Post by: RICKG on April 19, 2018, 03:11:44 PM
Nice, you're gonna love the 11" brakes..
Post by: mtnman37879 on May 11, 2018, 05:57:39 PM
Coming right along! Axles are on the springs, 11" brakes are complete, front suspension is complete, shocks installed and the wheels are aligned. I bought the *crap bell crank repair parts from OMX. They were looser that what I took out. Sent them back for a refund. Spent $54 on a NOS repair kit from Obsolete Automotive Warehouse. It is a large bronze bushing and center bolt. Fits and feels like new! Ya get what ya pay for! I re-engineered the brake/clutch shaft. I made nylon washers that fit snug on the shaft to act as a grease seal. Made a bushing to fit between the brake pedal and clutch arm to replace the washer and cotter pin. then I made the anti-wobble bolt to hold it all together, feels like new! My Willys, just like most new cars now requires a 10mm wrench, the reproduction brake lines have US threads but the hex is 10mm. The transfer case and transmission are next...
Post by: mtnman37879 on May 24, 2018, 01:34:33 PM
Started tearing into the transfer case today. Doesn't look too bad but I'll replace all the bearings, shafts and thrust washers. I also pulled the trigger on a new Saturn overdrive. I bought it from Kaiser Willys. They had the best price, $1049.99 with a shifter kit and free shipping. Who has the double lip seals?
Post by: athawk11 on May 24, 2018, 03:19:28 PM
Ron Fitzpatrick Jeep Parts.
Post by: mtnman37879 on May 29, 2018, 01:02:35 PM
Working on the transfer case. Everything has been cleaned and inspected. All the threaded holes have been re-tapped. Case checked for cracks. Even the pilot bushing has been removed (PITA! had to cut it out cause the bread trick didn't work). Here's a few pictures, before and after. Waiting for parts to come in the mail. The transmission is next in line.
Post by: mtnman37879 on February 27, 2019, 07:39:26 PM
I haven't posted in a while here's some more pictures of progress. The tub is Smoke Gray Rustoleum and a Harbor Freight HVLP gun. One run, I'm going to leave it and let people wounder how it got a horizontal run. Let it sit for a few days and on the frame she goes! Wiring next...
Post by: 64CJ5 on February 27, 2019, 08:26:43 PM
An excellent job.  I really like the paint job on the fan.
Keep the pictures coming.
