Your Projects => Non-Jeep Projects => Topic started by: garage gnome on February 20, 2016, 07:55:43 PM
Title: 1926 Fordson
Post by: garage gnome on February 20, 2016, 07:55:43 PM
My dad and I picked this up yesterday. Its a 1926 Fordson. I have to do a little tinkering with it to get it running. The guy that we got it from said it was a pain to start. I think it just needs a little more adjustment.
(http://i748.photobucket.com/albums/xx125/willyscjmj/D7A8FDD0-A827-40E6-AFD7-00E2F45EF380.jpg) (http://s748.photobucket.com/user/willyscjmj/media/D7A8FDD0-A827-40E6-AFD7-00E2F45EF380.jpg.html)
Title: Re: 1926 Fordson
Post by: Ryan_M on February 20, 2016, 09:09:52 PM
Love it! "Street tires" are pretty cool too.
Post by: garage gnome on February 21, 2016, 01:23:08 PM
Here are some more pictures now that it is unloaded.
(http://i748.photobucket.com/albums/xx125/willyscjmj/8AD8ECA5-6F15-4D05-8C53-34E388DD3C0E.jpg) (http://s748.photobucket.com/user/willyscjmj/media/8AD8ECA5-6F15-4D05-8C53-34E388DD3C0E.jpg.html)
(http://i748.photobucket.com/albums/xx125/willyscjmj/00653AAC-FEEB-4A53-8879-C7269D6DA509.jpg) (http://s748.photobucket.com/user/willyscjmj/media/00653AAC-FEEB-4A53-8879-C7269D6DA509.jpg.html)
(http://i748.photobucket.com/albums/xx125/willyscjmj/D67B5ACD-0005-4D2D-B3E3-DF8F3FB4E3FD.jpg) (http://s748.photobucket.com/user/willyscjmj/media/D67B5ACD-0005-4D2D-B3E3-DF8F3FB4E3FD.jpg.html)
Post by: garage gnome on February 21, 2016, 01:24:22 PM
It has a pickering governor which I guess is pretty sought after. Its not hooked up yet.
(http://i748.photobucket.com/albums/xx125/willyscjmj/4B184959-E731-4B92-8190-34DA8B5D75B2.jpg) (http://s748.photobucket.com/user/willyscjmj/media/4B184959-E731-4B92-8190-34DA8B5D75B2.jpg.html)
(http://i748.photobucket.com/albums/xx125/willyscjmj/A3A142EF-0295-417C-81F1-0ADE6AE0EB7A.jpg) (http://s748.photobucket.com/user/willyscjmj/media/A3A142EF-0295-417C-81F1-0ADE6AE0EB7A.jpg.html)
Post by: 1955CJ-5 on February 21, 2016, 05:43:41 PM
Very cool...!
Is it magneto ignition?
Or maybe those Model T type coils?
Post by: garage gnome on February 21, 2016, 08:05:14 PM
It uses buzz coils and there is a magneto on the flywheel just like the model T's.
Post by: 1955CJ-5 on February 21, 2016, 08:59:31 PM
I did a little reading as I never really understood the Model T ignition....
http://www.mtfca.com/encyclo/Ignition.pdf
I still don't quite understand it, but if I read it a couple more times maybe I'll get it...!
I look forward to the video!
Post by: garage gnome on February 21, 2016, 09:33:38 PM
It works the same as a regular coil and battery setup, just each spark plug has its own coil. It also works 180 degrees out of a regular coil. The buzz coils make a spark when the points are closed instead of a regular coil which makes a spare when the points open. There is a distributor of sorts on the front of the engine to tell which coil to fire.
Post by: 1955CJ-5 on February 21, 2016, 10:59:57 PM
I guess it's a little like a modern ignition where each spark plug has it's own coil and the distributor, rather than directing the high voltage to the plug, sends the low voltage to each coil...
The flywheel based magneto is interesting...kinda like old lawn mowers with the single magnet in the flywheel...this just has multiple magnets...
But what closes the points...is there a solenoid of sorts inside the coil box..? I have a couple of those old coils, ought to look them over....
Post by: garage gnome on February 22, 2016, 06:15:01 AM
There's no solenoid. The distributor is the "points". I think you are getting confused with he points that are on top of the coil. When electricity is sent through the low tension coil, the magnetism from that makes the points on top of the flutter which sends the spark to the spark plug.
Its much easier to understand when you look at a single cylinder engine. Maybe this will help.
http://www.old-engine.com/magbuz.htm
Post by: 1955CJ-5 on February 22, 2016, 10:51:51 AM
The coil box points are the one's I was thinking of...just wondered what made them "flutter"...
I'll look at the T coil that I have and see if I can give myself a jolt!
Post by: johnrb3b on February 23, 2016, 12:42:37 PM
Wow Nate.
That's a really clean looking one.
After rebuilding the IH this should be a piece of cake.
Post by: garage gnome on February 23, 2016, 09:40:10 PM
I'm not sure which is worst. Diving in a project that no one has touched or starting with something that is done and just needs the bugs worked out of it.
Post by: johnrb3b on February 24, 2016, 01:25:06 PM
Ah yes, the hazards of the infamous P.O.
 :P
