Your Projects => Non-Jeep Projects => Topic started by: F Bill on September 03, 2013, 10:10:45 PM
Title: Chevy woes..
Post by: F Bill on September 03, 2013, 10:10:45 PM
Today I drove to Garden City, KS, to pick up an oversize job.. and as I pulled into town I heard a Chuffing noise... I thought that's something new.. About 15 minutes later I found out what it was as a spark plug blew out of the left head on an onramp.
Now I bought the truck with a lot of miles on it, and the plugs had not been changed recently when I bought it, so I had the Chevy dealer install plugs and wires, when they fixed a computer issue it had. I figured if it was messed up and a plug stuck, they'd be able to fix it ..but the change happened with no problems whatsoever.
Fast forward 10 months....and the plug pops out. Obviously it was in a substandard hole and was barely holding on when it got installed. Not a thread was left in the hole. Sure hope more plugs were not in bad holes. TEH kicker was the lifetime guaranteed wire set was installed with no dielectric grease on the boots, and the wire end handily pulled right off one wire. RRRGH!
So, paying Rapid Chevrolet's high price service techs to do a job was not worth it. I could have gotten that sort of work at the local high school shop from trainees!!
Anyway, $110 in new wires, helicoil, spark plug, and helicoil tool later, and it runs well again. What a royal pain.
moral of the story... Change plugs more often, use never seez and dielectric grease, and avoid the dealer.
Title: Re: Chevy woes..
Post by: johnrb3b on September 04, 2013, 12:30:17 PM
... and avoid the dealer.
That's the key phrase from the entire post.
You cannot trust the mechanics at a dealership. Even if you do find a good mech, there's no guarantee he'll be the one to touch your car. And most dealerships' mech shops have a revolving door. The good guy may be gone the next time you go there.
Find an independant who's good, trustworthy and stable.
I've been using the same mechanic for 28 years and his son is inheriting the business. He's also a good mech so I'm good for another generation.
Oh, and, what are the odds the idiot used an air wrench to put the plugs in? They do it to lug nuts on your tires. Every car manufacturer says to use a torque wrench on the lug nuts and every dealership uses an air wrench running at 90 lbs.
Post by: Bob W on September 04, 2013, 04:36:03 PM
Those darn dealership technicians  ;)
Post by: PaulS on September 04, 2013, 11:14:37 PM
I use my local Chevy dealer, and have since my first Chevy in 1997.  Heck, I've only bought GM since then so I wouldn't have to worry about finding a new service location.  They even stock the oil filter for my wife's Pontiac Vibe--which no Chevy uses--just for me.  While some of the staff rotate frequently, the service manager and shop manager and parts manager have all remained constant in that time.  If something's not right, they make it right.
I do recognize that not all dealers are that good, though!
-Paul
Post by: johnrb3b on September 05, 2013, 09:59:42 AM
You are a lucky man.
That's a rare dealership.
I know of a couple more scattered across the country.
Post by: p3ferris on September 06, 2013, 12:18:57 AM
Some things at the dealership have a lifetime guarentee.  See if it is for them  then give the bill to them to repay you. If they dont then you are out your time and you can tell the owner that you had work done there and it was bad.  The reputation spreads quickly
